Home -> Forums -> Construction -> Foundation -> Raft and Mat Foundation, both are same or different?
Tue Mar 15, 2016Total posts : 2
sayeedmohsin
sayeedmohsin
Topic: Raft and Mat Foundation, both are same or different?
Raft Mat Foundation both are same or different?
Area 95’x65’ = 6200 Square Feet
Should I go Excavation 5’ or 10’ deep?
What will be the cost of Raft Foundation + 35 Columns of 1.5’x1.5x10’ height (2’ included extra from ground level) + Beams 1.5’x1.5’
Kindly tell me the cost/ Square feet + Labors charges, total cost?
Really, you are providing a great benefit to the society, God bless you
Thanks and best regards,
Wed Mar 16, 2016Post  #1
Dear Sir
        The depth of foundation is taken from the bearing capacity of soil/ land. In general the foundation depth should be up to hard strata of soil and minimum 4 feet.The cost of raft foundation and other component can be calculated after the structural design. Because in  the design the thickness of foundation and MS Steel is calculated according to load coming or bear by the foundation irrespective of bearing capacity of soil and taking safety factor and safety from earth quack etc.
In my opinion you should act according to technically as your project is big and take no risk for a small amount of design. If we have proper design than we save the cost by tentative method and with safety in mind.
http://www.gharexpert.com/tips/articles/Construction/1730/Cement-Concrete-1730-Mild-Steel-Bars-in-Cement-Concrete_0
Thu Mar 17, 2016Post  #2
sayeedmohsin
sayeedmohsin
Post subject: Raft Mat Foundation both are same or different?
Many thanks for your prompt reply and information.
Indeed, it's very useful. God bless you
2253
Underground water tank
13268
Steel Type
2059
Should persons with different name and or profession have main door entries in d
Last answer on 2/5/2022 2:03:11 AM. Forum started by Vinod Kothari
2958
Need suggestions
1670
Last answer on 5/3/2016 12:13:14 AM. by JAI PRAKASH. Forum started by sayeedmohsin
1890
1065
2248
Flooring for house
Last answer on 1/17/2022 11:13:36 AM. by S L Gupta (Civil Engg). Forum started by Archit Jain
i want different designs of pooja ghar
Last answer on 7/3/2020 9:49:04 PM. Forum started by vrinda thatte
2301
show me different pop design
Last answer on 10/4/2012 3:26:01 PM. Forum started by Afolabi Tope
1983
what are the different good wooden flooring options available...pl suggest
Last answer on 5/23/2011 10:12:30 PM. by S L Gupta (Civil Engg). Forum started by Reena
2568
very nice picture and very different also.
Last answer on 10/9/2020 12:49:36 AM. Forum started by AMITKATHURIA
2292
I want to know where different valves are used in a residence
Last answer on 10/3/2010 10:46:43 AM. Forum started by smita pathak
2303
i want to see different type of POP on ceiling
Last answer on 12/31/2020 2:33:42 AM. by jaydeep. Forum started by radheshyam
2740
Wooden Flooring
Last answer on 2/9/2021 5:39:37 AM. by Prakash Pandey. Forum started by atiq khan
3268
2308
i would like to see some different color combinations as well
Last answer on 4/28/2010 1:15:34 PM. by juhi. Forum started by fawad
2484
door design
Last answer on 2/14/2014 4:17:10 PM. by Navneet Jharia. Forum started by chethan
2684
Pillar
2140
Curing urgent
2372
structure work
5166
Pillar foundation
2204
new house
2821
building a house
1992
Construction Agreement
3091
Foundation
2272
Foundation
1477
10048
3660
Foundation
2115
Structure proof checking
2558
Foundation design
2462
2468
Saria and cement
3657
Wall Thickness
2679
3180
13268
Steel Type
Designing
Designing a Foundation
Bathroom Accessories Part-4
Carpet
Carpet Cleaning Tips
Appropriate
