Sat Jun 29, 2013 | Post #1 | Purvi Panchal
Sun Jun 30, 2013 | Post #2 | Rudra Nevatia
One possible reason is that concrete did not flow around the conduit causing a honey-comb through which water has started leaking.
Conduit should have a minimum cover of 50 mm and its diameter should not exceed 1/3 of slab thickness.
Regards, Rudra Nevatia
Sun Jun 30, 2013 | Post #3 | Navneet Jharia
Join date: Dec 2010 | Post subject: Rain Water leakage thru electrical conduit in RC...
For The Leakage through Electrical points and conduits kindly check the storage of rain water on terrace, if slope of terrace is proper , check rain water outlets..and clean. also check the joints of RCC slab and brick wall,where Electrical bands are provided...Please Insure Good quality of Elect.Conduit fittings J-box,fan box ,bands etc.with Good workmanship...... | |
