Home -> Forums -> Construction -> Earth -> Rainwater Saving Earth pits
Fri Sep 25, 2015Total posts : 1
Bharat Kumar
Bharat Kumar
Topic: Rainwater Saving Earth pits
Want to know in detail process and procedures for rainwater saving earth pits.
How it will prepared and what is the budget for each earth pits.
And also how it will be maintained.
Bharat Kumar
Mon Sep 28, 2015Post  #1
Water is a scarce resource. The reality of water crises can not be ignored. In India water resources management is poor. Extraction of ground water is being done in unplanned and uncontrolled way and this has created problems such as:
  • Hydrological imbalance.
  • Deterioration in water quality.
  • Rise in energy requirement for pumping water.
Rain water harvesting is an age-old system of collection of rain water for future use. The systematic collection and recharging of ground water recently gaining importance as one of the most feasible and easy to implement remedy to restore the hydrological imbalance and prevent a crisis.
There are two main techniques of rain water harvesting, one is storage of rainwater on surface for future use and other is recharge rainwater to ground. In this article we provide details about Building Bye-Laws, about use of ground water, rain water harvesting and roof top rainwater harvesting.
Amendment To Building Bye-laws:
The rising demands of water in urban area cannot meet through available surface water. To meet the demand, ground water is used and over-exploited resulting in decline of the ground water levels and deterioration of the ground water quality. To over come this situation, Government amended the Building Byelaws in august, 2001 making water harvesting through storing of water run off including rain water in all new buildings on plot of 100 sq. meters and above mandatory in National Capital Territory of Delhi with immediate effect.
Ban On Abstraction Of Ground Water:
Central Ground Water Authority, Ministry of Water Resources, has imposed a ban in the Notified area of Delhi and Haryana on abstraction of ground water by private agencies for commercial purposes. The indiscriminate abstraction of ground water has resulted in decline in ground water level and deterioration of ground water quality.
Adoption Of Roof Top Rain Water Harvesting System:
Central Ground Water Authority, Ministry of Water Resources, has also made mandatory in NCT Delhi adoption of roof top rain water harvesting systems for all Group Housing Societies for ground water recharge in their premises.
Rain Water Harvesting:
In the Rain Water Harvesting system, the rain water is collected and storage either for direct use or for recharging the groundwater. The term water harvesting means to prevent the losses of water either through evaporation and surface run off. In water harvesting system, it also includes engineering activities aimed at conservation and efficient utilization of limited water endowment of an area.
Rain is primary source of water and river, lakes and ground water all these are secondary source of water. At present times, we entirely depend on secondary sources of water. It is matter of great concern that ground water resources are receding day by day. To over come this problem, we should take full advantage from the primary source of water i.e. rain. Rain water needs to be scientifically pursued for the optimum utilization of its potential.
Roof top rain water harvesting is technique through which rain water is captured from the roof catchments and store in reservoirs to meet the house hold needs. The catchments area also includes compounds or artificially prepared impervious/ semi-pervious land surface. The latest development in efficient and scientific design of ground water recharge structures has provided impetus for systematic collection of roof top rain water for recharging the sub surface ground water aquifer. This process enhances the availability, reliability and quality of ground water at specific place and time.
Advantages of roof top rain water systems:
1. Rain water harvesting system to recharge the ground water, enhance the availability of ground water and assures continuous and reliable access to ground water.
2. Capturing and storing rain water for use is particularly important in dry land, hilly, urban and coastal areas.
3. Save the energy, for 1-meter rise in ground water level is around to save 0.40Kwh of electricity.
4.The problem of choking the storm water drain is reduced due to reduced surface runoff of rain water.
5.Avoid Flooding of roads.
6.Reduce soil erosion.
7.Reduce the cost of pumping of ground water.
8.Reduce ground water pollution and improve the quality of ground water through dilution.
9.Recharged ground water provides good quality water which is soft and low in minerals.
10.The roof top rain water harvesting is less expensive, easy to construct, operate and maintain.
Earth-Construction Questions (23)
2041
Soak pit location in industrial plot
Last answer on 5/21/2019 1:35:08 AM. by JAI PRAKASH. Forum started by navin
3145
What are advantages and disadvantages of iron doors?
Last answer on 1/30/2010 9:20:41 AM. by S L Gupta (Civil Engg). Forum started by rajesh malik
45463
how much cu.m of earth can excavated by machine per day
Last answer on 4/3/2021 12:46:18 AM. by prasadtvp. Forum started by sherab tenzin
6414
2339
lift pit water proofing
2474
Septic Tank Design
3562
space saving ideas for kids bedroom
Last answer on 9/29/2021 10:56:44 PM. Forum started by mandep
4702
How can we save money and less wasted through vastu tips at home
Last answer on 7/4/2020 2:01:06 AM. by Deepti. Forum started by shalini kulshreshtha
2606
3946
How to save YouTube videos to iPhone?
Last answer on 1/31/2022 4:20:00 PM. by Erling. Forum started by weridikka
2059
Last answer on 10/15/2014 8:31:38 AM. by SANJAY DUSANE. Forum started by naresh
1812
I would like to construct building with Earth quake resistence
Last answer on 5/24/2013 12:11:09 PM. by S L Gupta (Civil Engg). Forum started by ananth
4443
lobar work quantity
2063
concrete filling
Last answer on 4/18/2014 7:54:24 PM. by shaik khaja nayab rasool. Forum started by shaik khaja nayab rasool
3361
cost saving in construction of house
Last answer on 8/17/2020 2:10:30 AM. by foro. Forum started by raviprakash
2003
Saving an article
Last answer on 9/28/2012 4:51:05 PM. by Amit Hasija. Forum started by amzad
1833
Hello, How can i save Esitmated as file? excel or word, please give me tip, than
Last answer on 2/12/2012 4:35:47 AM. Forum started by jaffar khan
2275
how much discount will i get on havel and anker and jagur and which one is good
Last answer on 7/26/2012 10:56:04 PM. by Ar. Manoj Ralen. Forum started by ripudaman
2503
2180
pile work
1709
Det fører til overstriding i Tillegg til utvidet knusende
Last answer on 1/20/2017 2:09:02 PM. Forum started by farofaschafer
1537
borewell drilling effect to pile colom
Last answer on 4/27/2014 3:44:03 AM. by serin. Forum started by paresh
2482
map design
Last answer on 4/14/2014 11:28:10 AM. by S L Gupta (Civil Engg). Forum started by sushil
Energy
Energy Saving Fans
Everyday rising energy demands reminds us to explore new energy saving devices. Energy saving ceiling fans is such a d..
60
60 Tips to Save Water
Energy
Energy Saving Tips
Saving energy will definitely help you minimize your energy/electricity bills. Here are some nice tips to save energy;..
Earth Filling
Earthing
How does earth quake affect the building?
The outer shell of the earth called lithosphere is broken into plates which are in constant motion, moving at about th..
Saving energy with uPVC Windows
