Analysis & Rates The capacity of doing work by an artisan or skilled labour in the form of quantity of work per day is known as the tas.. |
Labor Contract vs. material contract In building construction work, there are many aspects or things to be done by building owner such as arranging drawing.. |
| Purchasing Guidelines for Coarse Aggregate Sub standard material reduces the strength of RCC, Reinforced Cement Concrete, by 10 to 30 %. Use these steps to ensur.. |
| Why an Architect should be hired? We recommend that an architect should be appointed for the construction of any house as the professional help would be.. |
List of construction activities in sequence Before going for any construction do you know what the sequence of construction activities is? Here is a list of const.. |
| Home Construction Safety There are several home construction safety tips which can be applied during construction of the house. This article wi.. |
Stair construction-Things to remember Stair construction needs major consideration while you are either building a new home or just doing any renovation. Th.. |
