Rcc Column construction (250x300 with 6-12dia. rod) for 2storied residentiial bu
Mon Nov 12, 2012Total posts : 1
Swarup
Swarup
Topic: Rcc Column construction (250x300 with 6-12dia. rod) for 2storied residentiial bu
Rcc Column construction (250x300 with 6-12dia. rod) for 2storied residentiial building (around 85sq.ft.) was done as advised by one of my friend.Now I am worried that weather it is safe or not? if not please suggest the remedy. only ground floor superstructure has been construted. I will start construction of 1st floor by mid december. any safety measure needs to be taken during construction of 1st floor. Please advise.
Mon Nov 12, 2012Post  #1
Dear Swarup
           The provision of MS Steel rod nos and dia for making RCC columns are depend upon the load coming on the column, span of the column. From your question it is not clear what length of span is. In my view you should contact any civil engineer or structural engineer who can give you suggestion after visiting your home.
Rcc Column construction (250x300 with 6-12dia. rod instead of 4-16dia.) for 2sto
Last answer on 12/6/2012 2:41:14 PM. by S L Gupta (Civil Engg). Forum started by Swarup
4051
RCC Column
Last answer on 10/22/2013 4:25:37 PM. by S L Gupta (Civil Engg). Forum started by Swarup
2807
2201
Brick Masonry Columns
Last answer on 1/14/2014 12:50:59 PM. by Ahmed. Forum started by Ahmed
2719
1057
Hi All,Is there any difference in strength of column, if we use 8 no of 12mm rod
Last answer on 8/20/2018 12:42:59 AM. by S L Gupta (Civil Engg). Forum started by vishal singh
1041
Last answer on 8/20/2018 12:41:32 AM. by S L Gupta (Civil Engg). Forum started by vishal singh
4128
2244
2616
COLUMN nd LOAD BEARING
2600
RCC Column Construction
Last answer on 3/3/2014 11:50:44 AM. by S L Gupta (Civil Engg). Forum started by Anuj Prakash
3030
2185
Bending the pillar rods on first floor
Last answer on 10/13/2016 11:16:31 AM. by S L Gupta (Civil Engg). Forum started by Saneto Fernandes
1064
Gupta sir,My G 1 house constructed having 12 columns of size 15x9 inches.8 no co
Last answer on 9/10/2018 11:46:10 PM. by S L Gupta (Civil Engg). Forum started by Santosh Reddy
1698
TMT rod to be used for the structure
Last answer on 10/3/2015 11:39:32 AM. by S L Gupta (Civil Engg). Forum started by nhrajesh
9885
65238
3941
