Home -> Forums -> Construction -> Cement Concrete -> Ready Mix Concrete
Ready Mix Concrete
Sun Apr 14, 2013Total posts : 21
sck
sck
Topic: Ready Mix Concrete
Can a 4`` x4`` beam of M 20 be laid over ground floor wall to start work on 1st floor
The comment above talks about the article   "Ready Mix Concrete"
Go to page: 1 2 Next   >>
Sun Apr 14, 2013Post  #1
Hi: I believe the wall on ground floor that you are talking about is 4.5" thick. It would be dangerous to lay a simple 4"x4" beam without support of any roof slab and continue building upon the beam.
Your question certainly lacks details. Without looking at the plans and your actual requirements, it is very difficult to comment upon the situation.
Mon Apr 15, 2013Post  #2
Dear Sck
          It not necessary to lay beam on wall for first floor if walls is load bearing in structure. To write a line could not serve the purpose.When one is spending lacs of rupee for construction house but shrinks spending on proper planning, which shall prove costly latter on.I  am in view that you should contact any civil engineer, architect of your town or city and get decision after visiting the site personally.
Tue Apr 16, 2013Post  #3
sck
sck
Post subject: construction of 1st floor
All the walls are either 4.5 inch or 9 inch thick. Beams for 1st floor are being placed over the roof of ground floor and over the walls. But two beams are on roof but well supported by ground floor walls at a distance of 10 ft . Rest all are firmly on ground floor walls. I intend to use  concrete mix of M 20 grade.
regards,
SCK
Ghaziabad
M : 9311850660
Thu Apr 18, 2013Post  #4
Dear SCK
        If You constructed ground floor wall load bearing than by giving load of beam on load bearing wall than it is OK. M 20 conc means 1;1.5;3 ratio.
Thu Apr 18, 2013Post  #5
sck
sck
Post subject: Construction of 1st floor
Dear Sir,
Thanks for reply. As per my information, M 20 means 1 (cement) : 1.5 (Badarpur) : 3 (Moti Rori). Beams are already laid and they are crossing each other at 90 degree and are also supported by load bearing walls at different intersections.
Now I intend to build brick walls over the beams leaving spaces for walls and windows. I intend to go up to 9 ft in height for doing shuttering. What can be ideal dimensions for doors and windows and height for walls. Kindly suggest.
regards,
SCK
Fri Apr 19, 2013Post  #6
Dear SCK
           The 9 feet height of wall is right. Door size for room 3'x7' and for toilet 2.5' x7'. Window size taken to be according to room width or 4'x4' etc.
Fri Apr 19, 2013Post  #7
sck
sck
Dear Sir,
Thanks .
regards,
SCK
Mon Apr 22, 2013Post  #8
sck
sck
What is the standard size of shuttering steel plates for laying roofing. I intend to start shuttering at 9 ft height.
1. How many  steel plates, Pallus and ballies are required for roof size of 1000 sq ft area.
2. What should be size of Jalli - rod mesh (7 inch or 8 inch) and thickness of TMT bars (12 mm or less) for roof of 1st floor
regards,
SCK
Mon Apr 22, 2013Post  #9
Dear SCK
         The shuttering plates are of various size such as 2'x2' or 3'x1.5' or 2'x1.5' as per availability in your town or city. The mason will tell you about the materiel required.
  The spacing of rod 6''x6'' 12 mm dia.
Mon Apr 22, 2013Post  #10
sck
sck
Thankx and what should be the thickness of RCC roofing (4 inch or 5 inch). I intend to use M 15 or M 20 grade concrete mix. Does the grade of mix have got any relation with thickness of roofing
Tue Apr 23, 2013Post  #11
Dear SCK
       Use cement concrete M20, it is safe against earthquake and keep thickness of slab 4.5'' to 5''.
Wed Apr 24, 2013Post  #12
sck
sck
Thankx. I will use M20 grade concrete mix and will keep thickness of RCC as 4.5 inch only as 5 inch will add more load over the structure.
I hope Jalli which u suggested as 6 ``x6`` of 12 mm dia TMT bars is a 2 dimensional thing  having length and breadth only;  if height of 6 `` is added, the whole thing will become beam like structure. I intend to place this Jalli in mid of RCC slab of 4.5 `` thickness before pouring M20 grade concrete mix. Is it okay.
Wed Apr 24, 2013Post  #13
Dear Sck
           The thickness of slab, dia of MS Steel bar and spacing is depend upon the span of the slab, so I already suggest you to plan the construction so that will ultimately give benefit. If the span of slab is up to 10 feet than 4'' slab is sufficient according to design and steel bars of 10mm dia is sufficient. Now without proper plan of the house and design, one can not tell exact thing. In my view to place 12mm steel bars at 4.5 '' is wastage of steel.
Thu Apr 25, 2013Post  #14
sck
sck
Total area of slab is approx 40`(length) x 30 ` (breadth) = 1200 sqft approx covering 2BHK. I can reduce size of TMT bar from 12`` to 10 ``,if desired keeping RCC thickness as 4.5 inch thick with M 20 grade mix
Thu Apr 25, 2013Post  #15
sck
sck
.Total area of slab is approx 40`(length) x 30 ` (breadth) = 1200 sqft approx covering 2BHK. I can reduce size of TMT bar from 12`` to 10 ``,if desired keeping RCC thickness as 4.5 inch thick with M 20 grade mix.
Dimensions of 2 BHK are as follows:
Total area of slab in sqft
1 DR -                    20 `x 13 ` =  260 sqft
1lobby -                14 `x 14` =   196 sqft
1 BR -                     18` x 13` =    244 sqft
1 BR-                      10` x 13`=     130 sqft
1 Kitchen             8` x 6`   =        48 sqft
Balcony               20` x 3` =         60 sqft
                                                         938 sqft
The above dimensions will give u idea on spans. I hope now u can suggest the size of Jalli and thickness of TMT bars , thickness of slab etc
regards
SCK
Fri Apr 26, 2013Post  #16
Dear Sck
        Use 12mm dia steel bar 6'' c/c and M20 slab 5'' thick.
Sat Apr 27, 2013Post  #17
SCK
SCK
Thanks, but what is `c/c` in 6 inch.
I understand, 12 mm TMT bars are to be placed lengthwise and breadth wise with spacing of 6 inch on both sides, so I will get a rod mesh (Jalli ) in Square shape. This rod mesh will be placed over shuttering for putting slab.
I hope when u write steel bars, u mean TMT bars only.
Could not respond to u earlier, due to log in problems and I have to create a fresh profile with same user id.
regards,
SCK
Mon Apr 29, 2013Post  #18
Dear Sck
       Your assumption is right, do your work further., lay slab
Mon Apr 29, 2013Post  #19
cleanroomproducts
cleanroomproducts
thats good
Sat Oct 05, 2013Post  #20
SCK
SCK
Post subject: stairs
Is concrete mix of M 20 is good enough for laying slab of slope and platform for stairs when TMT bars used is 12mm in sides and Jaal of 6 x 6 is of 10 mm
4372
Ready Mix Concrete
2157
Ready Mix Concrete
Last answer on 7/4/2020 2:18:20 AM. by S L Gupta (Civil Engg). Forum started by Vishwanath
1763
1457
1520
I understand there are various types of Ready Mix Concrete is available. For my
Last answer on 9/1/2015 2:45:51 AM. by JAI PRAKASH. Forum started by Chandrasekaran S
3769
concrete mix design software
3276
2135
READY MIX PLASTER
1686
6462
3388
1:2:4 mix or 1:3:3 mix
Last answer on 3/18/2014 1:08:38 PM. by S L Gupta (Civil Engg). Forum started by navneet
4365
WHAT IS THE RATIO
2466
1717
CONCRETE MIX
Last answer on 7/3/2020 9:36:11 PM. by M Prabhu. Forum started by M Prabhu
1869
Roof Painting
1742
Last answer on 9/22/2015 10:27:11 PM. by JAI PRAKASH. Forum started by meenal singhvi
2788
2547
Water for Construction
3791
3469
Cost of concrete walls
1793
STP
3107
3651
4349
rate comparison
3204
Concrete Mixture
3142
sloping roof
2090
15805
6470
2380
leakage in new slab
1528
Guide me
5119
2535
Civil Eng Stair Design
2535
Related to Sunken Slab
1858
1998
Concrete Hollow Block Masonry
2414
roof concrete
Ready
Ready Mix Concrete
Concrete Mix Ratio
CONCRETE
Concrete Decor
Ready
Ready Made Doors
Are you looking for appealing ready made doors for your home? Here is a variety of ready made doors to provide safety ..
