Home -> Forums -> Construction -> Start Construction -> Ready Mix Concrete
Ready Mix Concrete
Thu Dec 20, 2012Total posts : 1
Vishwanath
Vishwanath
Topic: Ready Mix Concrete
How Ready Mix Concrete is compared with the usual mechanical mixer ?
What are the advantages / disadvantages, cost effectiveness of using RMC ? Please reply.
Thu Dec 20, 2012Post  #1
Dear Vishwanath
Ready Mix Concrete, popularly known as RMC refers to a concrete mix in  unhardened state, manufactured especially for construction site. In traditional construction works, each constituents of concrete mix is mixed in specified proportions at site by the labor which is not always accurately mixes as the process is manual. However RMC is mixed mechanically so is more accurate mixing. See the article below for more details.
http://www.gharexpert.com/articles/Cement-Concrete-2006/Ready-Mix-Concrete_0.aspx
4372
Ready Mix Concrete
3199
Ready Mix Concrete
1763
1457
1520
I understand there are various types of Ready Mix Concrete is available. For my
Last answer on 9/1/2015 2:45:51 AM. by JAI PRAKASH. Forum started by Chandrasekaran S
3275
3769
concrete mix design software
2135
READY MIX PLASTER
1686
6462
3387
1:2:4 mix or 1:3:3 mix
Last answer on 3/18/2014 1:08:38 PM. by S L Gupta (Civil Engg). Forum started by navneet
2465
1868
Roof Painting
4365
WHAT IS THE RATIO
1717
CONCRETE MIX
Last answer on 7/3/2020 9:36:11 PM. by M Prabhu. Forum started by M Prabhu
2787
1742
Last answer on 9/22/2015 10:27:11 PM. by JAI PRAKASH. Forum started by meenal singhvi
2547
Water for Construction
3791
3309
2133
2059
Ready
Ready Mix Concrete
Concrete Mix Ratio
CONCRETE
Concrete Decor
Ready
Ready Made Doors
Are you looking for appealing ready made doors for your home? Here is a variety of ready made doors to provide safety ..
