Readymix Concrete Mixture
Thu Aug 16, 2012Total posts : 1
Navneet Shahrawat
Navneet Shahrawat
Topic: Readymix Concrete Mixture
I want to know the advantages and disadvantages of of readymix concrete mixture for Rcc work for roof and basement flooring.
  1. How does it compare in costs and quality to that prepared locally on site?
  2. What important points to be noted when choosing the concrete mix?
Thanks and regards
Navneet
Fri Aug 17, 2012Post  #1
jmahajan
jmahajan
Dear Navneet
The ready mix concrete is costly than site mix concrete
Benefits of ready mix concrete
  • Can meet the demand of cement concrete mix for wide area.
  • Offers better quality, and consistent mix than site mix concrete
  • Doesn’t require storage space for raw materials at site
  • Reduces noise and dust pollution at site
  • No need to procure/ hire plant and machinery at site of work
  • Time saving as the work is completed before time
  • Does not require hiring labor to mix concrete at site
  • Doesn’t need technical staff employed for production of concrete mix
Drawbacks of ready mix concrete
  • More expensive than site mix concrete due to transportation cost and modern additives which are used to increase time span in traveling.
  • Critical in case of sites at longer distance as the mix takes traveling time from central plant to the site.
Concrete Mixture
6489
3616
Per Sq:ft rate for flooring
1811
Need Advice on Solid Wood Floors
Last answer on 4/30/2014 8:29:12 PM. by Abhishek Garg (Builder & Engineer). Forum started by chintan arora
1774
1466
3476
Cost of concrete walls
3443
3289
2031
parts of concrete and size.
Last answer on 3/15/2011 6:16:45 PM. by S L Gupta (Civil Engg). Forum started by kanwer sajjad
2254
sand alternate for concrete
3777
3801
concrete mix design software
2279
2428
roof concrete
2422
20171
2161
1632
15
Love Vashikaran Specialist Astrologer in Nashik 91-9056562757
Last answer on 1/6/2025 3:03:02 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:03:01 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:03:00 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:02:59 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:02:57 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:02:56 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:02:55 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:02:53 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:02:52 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:02:51 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:02:50 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:02:49 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:02:48 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:02:47 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:02:46 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:02:45 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:02:44 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:02:43 AM. Forum started by Pandit Sahil Sharma Ji
Last answer on 1/6/2025 3:02:41 AM. Forum started by Pandit Sahil Sharma Ji
Concrete Decor
Concrete Mix Ratio
Ready
Ready Mix Concrete
Tips for Cement Paint
