Really an informative article on rat trap bond.helping me a lot.just to ask that
Fri Dec 30, 2016Total posts : 1
sabrina
sabrina
Topic: Really an informative article on rat trap bond.helping me a lot.just to ask that
Really an informative article on rat trap bond.helping me a lot.just to ask that is it possible to place wood stud and foam in between the cavity of the bond for better sound insulations for a particular room like music/dance studio? thanks in advance.
Fri Dec 30, 2016Post  #1
Dear Sabrina,
          Yes you can do it.
2404
3234
Ferrocement channels roofing Vs Rcc slab
Last answer on 9/15/2021 9:04:11 PM. by S L Gupta (Civil Engg). Forum started by Sameer S Pawade
2443
Dining Furniture
Last answer on 8/7/2010 5:55:27 PM. by nalini persad. Forum started by ashu jain
1511
Electrical wiring
Last answer on 11/1/2015 6:41:12 PM. by JAI PRAKASH. Forum started by ani
3133
false ceiling
1944
RATS PRESANTS IN SHOWROOM GOOD YA BAD
Last answer on 1/17/2012 6:21:32 PM. Forum started by KAPIL
2818
Last answer on 2/13/2012 3:19:03 PM. by PR Jawahar. Forum started by pallubc2
8962
are keeping rats good for vastu in house
Last answer on 8/20/2012 11:04:19 AM. by Amit Hasija. Forum started by aditya
1778
How I can buy this s trap
Last answer on 6/8/2013 6:14:17 PM. by Navneet Jharia. Forum started by joemon
1798
what is the diffrence between s-trap and p-trape
Last answer on 7/29/2014 2:29:59 PM. by S L Gupta (Civil Engg). Forum started by SANJAY DUSANE
1726
WHICH TRAP IS USED FOR INDIAN AND EUROPIAN W.C.
Last answer on 7/30/2014 9:21:40 PM. by Purvi Panchal. Forum started by SANJAY DUSANE
2684
Bedroom Styles
Last answer on 7/2/2020 10:08:15 PM. by FRAZ. Forum started by kamal akhtar
3917
wat do u think if u are a student of interior designing ( about ur field)?
Last answer on 1/20/2022 1:01:00 AM. by JAI PRAKASH. Forum started by swati
2896
Last answer on 12/16/2009 5:20:05 PM. by Asit Patel. Forum started by A.S Rajkumar
Please help re-order house
Last answer on 7/12/2012 10:36:14 PM. by Amit. Forum started by Amit
1110
Fresh cut bank instrument for lease/sale, such as BG,SBLC, MTN, Bank Bonds,speci
Last answer on 1/7/2021 2:27:50 AM. Forum started by marga
1702
hi i really love the design but i really want to see the inside of it thank
Last answer on 4/18/2015 9:38:38 PM. by JAI PRAKASH. Forum started by Yordanos
1704
plans for a 26x40 house on an 80x100 lot..lot facing east.what are the best plan
Last answer on 10/27/2015 6:39:01 PM. by JAI PRAKASH. Forum started by lauretta
Brick Bonds
Do you know good brick bonds can ensure the strength of a building? Only you need to select appropriate bond for walls..
Traps
Traps - Types and Uses
Proper drainage system is essential for waste water of the house. Traps and water seal are an important part of draina..
Points Management @ GharExpert.com
Points Management System To encourage participation, GharExpert provides a system of points.
