Home -> Forums -> Construction -> Dampness -> Reasons of dampness
Reasons of dampness
Thu Dec 22, 2011Total posts : 1
kamal hossain
kamal hossain
Topic: Reasons of dampness
how to protect/reduce the heat of top floor .
The comment above talks about the article   "Reasons of dampness"
Fri Dec 23, 2011Post  #1
Dear Kamal
By doing thermal insulation you can reduce the heat from top level.Thermal insulation is a method to reduce the transfer of heat from outside to inside. To make house heat proof, thermal insulation is a good choice. An insulated home is more comfortable as t he temperature remains consistent over weather changes. It makes the house comfortable and keeps the temperature of   house cool in summers and warm in winters. It is very useful to keep the temperature of the house independent from outside temperature see link givenbelow. http://www.gharexpert.com/articles/Finishing-1607/Thermal-Insulation-Home_0.aspx
Dampness-Construction Questions (35)
2379
dampness in bathroom,loft and staircase
Last answer on 8/19/2013 11:25:13 AM. by S L Gupta (Civil Engg). Forum started by Arun
3490
How to solve dampness in wall
Last answer on 11/17/2016 10:58:15 AM. by Girish. Forum started by Rajan
3291
2362
dampness in corners at the junction of walls and floors
Last answer on 3/9/2011 12:14:27 PM. by Nenni. Forum started by AN CHORDIA
2126
Dampness problem: In my new home, the house adjacent to me has dampness in the w
Last answer on 6/22/2009 3:15:25 PM. by Gunjan Utraja. Forum started by George
3673
sunken slab
Last answer on 7/3/2020 11:00:06 PM. by S L Gupta (Civil Engg). Forum started by chethan
1997
2032
Last answer on 1/28/2011 10:11:15 AM. by Nikita. Forum started by gururaj s sannakki
2143
how do you stop dampness in old buildings especially if it is due to burst conce
Last answer on 11/13/2010 8:21:32 PM. by S L Gupta (Civil Engg). Forum started by sangameshs
2016
1836
East-center Master bedroom - any reasons to worry?
Last answer on 2/23/2015 10:43:12 AM. by Pavan. Forum started by paramarsh
3411
Reasons and Ways to Keep the Kitchen Cleaning in Gurgaon
Last answer on 7/3/2020 10:45:19 PM. by JAI PRAKASH. Forum started by yash dahiya
2290
Last answer on 1/5/2022 2:14:28 AM. by JAI PRAKASH. Forum started by chethan
1989
Last answer on 4/26/2015 5:52:24 PM. by JAI PRAKASH. Forum started by chethan
1680
Last answer on 4/20/2015 1:18:43 AM. by JAI PRAKASH. Forum started by chethan
1760
Last answer on 4/20/2015 1:20:37 AM. by JAI PRAKASH. Forum started by chethan
2103
I am planning to fix sunshade at my home to stop dampness. The problem is the su
Last answer on 12/29/2011 6:15:24 PM. by S L Gupta (Civil Engg). Forum started by rajesh
2086
Last answer on 4/12/2010 8:36:47 PM. by haritha. Forum started by sujani
2674
Damp Proofing
Last answer on 12/31/2020 1:53:13 AM. by Mike Perkin. Forum started by VIPIN
3490
1860
Last answer on 12/24/2015 4:06:01 AM. by JAI PRAKASH. Forum started by sushantsah
1491
Canada Goose Chilliwack Bomber much likewise
Last answer on 11/14/2015 12:37:51 AM. by JAI PRAKASH. Forum started by farofaschafer
2072
2105
2130
Walls are damp in rain
2083
1883
Damp
Last answer on 4/4/2015 7:00:17 PM. by JAI PRAKASH. Forum started by Jag
1920
Leaking Ceiling
Last answer on 8/25/2014 8:26:28 PM. by JAI PRAKASH. Forum started by sandipvora
2762
1925
bathroom dampness
Last answer on 12/23/2013 12:21:54 PM. by S L Gupta (Civil Engg). Forum started by sunder
2570
Basement Leaks
Last answer on 10/24/2013 11:40:09 AM. by S L Gupta (Civil Engg). Forum started by Purvi Panchal
2365
water treatment for walls
Last answer on 4/27/2011 7:37:34 PM. by S L Gupta (Civil Engg). Forum started by gajender pathak
1748
2086
Protect
Reasons of dampness
Which type of DPC recommended for the protection of dampness?
For residential buildings DPC consists of a layer of - 40 mm thick cement concrete 1:2:4 (1 cement: 2 Coarse sand: 4 g..
Damp
Damp Proofing
