Plumbing
Tue Dec 22, 2015
Hema
Topic: Reconstruct house sump to increase storage capacity
Hi
We have a small sump in our building with storage of about 3000ltrs. There are two houses, ground floor and first floor dependent on this sump. Also water supply in our area is not good so we need to fill it up with tanker on a need basis. In order to increase capacity of sump so that we can make full use of water supply and tanker water we plan to demolish and rebuild the sump to have a storage of about 9000ltrs.
The sump is located in the parking space near the main gate but it does not spread across the whole vacant space till the main door. Is it alright if we take all the space from the gate till the door ? When we demolish the sump-walls adjacent to the house-walls will there be a huge impact on the house-walls. Is there a way to do the reconstruction carefully without damaging the house walls/foundation.
The house does not have pillars. Also we have overhead Syntex tank of capacity 1500 ltrs. Can we add more here?
Pl let me know.
Thank You
Wed Dec 23, 2015
Dear Hema
In my view it is better to take help from local of your city civil engineer who can better guide you after inspecting the house.
2. In my opinion you should not dismantle this but construct new one and connect both sump.
Wed Dec 23, 2015
Hema
Thank You Mr.S.L.Gupta for the answers.
I will check with a local civil engineer
~Hema
Thu Dec 24, 2015
Construct a new one as per your requirement and connect both.
3497
Last answer on 2/21/2021 8:33:40 AM. by
rameshkumar
rameshkumar
6579
Last answer on 10/16/2014 12:42:44 AM. by
NV MANI
1962
i want to reconstruct my 48sq mtr house in rohini bt dont know where to start fr
Last answer on 8/18/2011 11:14:53 AM. by
Anupama Verma
1636
West face House, can we construct North west side face sump
Last answer on 7/4/2020 2:50:11 AM. by
G.Mallikarjuna
40515
Last answer on 7/4/2020 2:50:25 AM. by
har
3174
Sump construction
Last answer on 2/26/2022 10:32:45 AM. by
bsubramanyam51
2071
Weight on Sump Tank
Last answer on 2/3/2021 11:35:35 PM. by
awdhesh
5733
Last answer on 7/4/2020 2:50:48 AM. by
NV MANI
NV MANI
4384
Last answer on 7/4/2020 2:05:07 AM. Forum started by
NV MANI
3079
Last answer on 1/2/2021 5:22:54 AM. Forum started by
NV MANI
2195
Last answer on 12/31/2020 8:58:35 PM. by
Joseph Santhosh
2100
Last answer on 2/14/2021 11:35:17 PM. by
Ravi sharma
1917
Water tank
Last answer on 10/1/2014 8:18:00 PM. by
karthik
2798
hai my house is constructed 7 years ago, now the roof slab is leaking year by y
Last answer on 7/3/2020 11:41:25 PM. by
vidya
2807
What is the cost of Home Lift capacity for four persons for four floors building
Last answer on 7/16/2014 7:56:03 PM. by
A Prasad
10065
cost estimation of water storage sump tank
Last answer on 9/26/2010 5:48:55 PM. by
sathish
manjuks
2442
Underground sump finished with granite/tiles
Last answer on 12/26/2014 2:16:16 PM. Forum started by
am.sridhara
2196
Hi Experts,I live in Bangalore. I have a requirement to construct sump of capaci
Last answer on 7/4/2020 2:50:00 AM. by
Jagadesh
10177
Last answer on 7/4/2020 2:49:28 AM. by
Amarnath
6270
Water Tank Quality
Last answer on 7/22/2021 5:19:42 PM. by
George Turner
Raman Mittal
3114
Hot Water Tank
Last answer on 1/9/2021 1:51:22 PM. by
Fox
Kanhaiya
2914
Sand in Water
Last answer on 12/31/2020 1:56:57 AM. by
yogiagarwal
Kanhaiya
3380
Diverters for Bathroom
Last answer on 11/4/2020 4:13:51 AM. by
perryjoseph
2561
Last answer on 7/4/2020 3:36:21 AM. Forum started by
pallubc2
40515
har
2083
GI pipe Vs CPVC pipeline
Last answer on 7/9/2018 12:35:54 AM. by
Rahul
2930
Last answer on 10/5/2016 11:34:14 AM. by
arun
arun
1754
Last answer on 4/22/2016 11:37:09 AM. by
jameel5
2079
Toilets
Last answer on 7/26/2015 4:31:26 AM. by
sandeep yadav
sandeep yadav
1987
Wall mounted cummod vs normal
Last answer on 7/2/2014 11:29:45 PM. by
awdhesh
5054
mohammed sadhiq ali
2774
Last answer on 1/25/2014 12:56:57 PM. by
chrome
1854
Last answer on 5/16/2013 2:56:28 PM. by
sam_m400
3074
Swimming pool
Last answer on 10/30/2012 12:08:21 PM. by
rajesh
2541
water softner
pallubc2
2681
commode type and flush type
Last answer on 5/26/2012 9:05:44 AM. by
pallubc2
4193
to shut off water to house
Last answer on 3/28/2011 9:36:11 PM. by
chris
chris
Kitchen Storage Ideas
Garage Organization
Garage has become the storage solution for the house. There is need to have proper garage organization to keep it clut..
Clutter Free Bathroom
Make your bathroom clutter free and organized using storage solutions. You can create storage spaces in walls, under ..
Vastu for Water Tank
What affects the life of doors? What can we do to increase the life of the Aluminium doors?
Tips to increase the life of Aluminium doors....
Storage Solutions for kids Room
Kids require a lot of storage space to place their toys and playthings. Proper storage ensures safety to the kids as c..
Kids Bedroom Furniture
Make your dream come true by putting unique furniture in kid’s room. Kid’s room needs storage areas because they need ..
Environment Friendly Houses
