Home -> Forums -> Construction -> Cracks -> Recurring Cracks
Recurring Cracks
Fri Apr 26, 2013Total posts : 1
Amar
Amar
Topic: Recurring Cracks
My house is undergoing maintenance ,I used Dr Fixit's CRack X to get ridding of crack on the plaster at the joint of RCC lintel and Brick wall and filled JK Wall Putty but surprisingly these cracks re occurred with a week,does any one have a solution.Lot of bloging sites (mainly from out of India) are  recommending to  put fiber mesh on crack  and plaster with 43 grade cement and make grooves.Will this help in India as well ?
Fri Apr 26, 2013Post  #1
Dear Amar
You should go to gharexpert.com web site, in construction there is section of safety where in sub section of crack, if you go through it than find lot of article relating to your problem and much more about construction and interior.
Repair Cracks on face of plaster
When two components having different elastic properties such as RCC slab and brick work abating each other, the crack on face of plaster is formed between these components due to their thermal expansion.
Remove plaster and old material
The plaster should be removed from cracked portion. The joints should be widened at least 20 mm to 25 mm in thickness. Clean old material by washing and brushing.
Apply cut and prepare the surface
Apply slight cut on edges in straight line to provide neat joint. Make the surface damp 24 hours before application of new plaster.
Apply cement mortar
Cement mortar should be applied on defective portion. Make 20 mm wide and 25 mm thick groove at the junction of two materials/components.
Do curing and finishing
Keep the surface wet at least for 3 days. When surface is dry, finish it according to adjacent area on wall.
Cracks in RCC surface
Repair cracks in RCC surface
Cracks-Construction Questions (30)
2502
2711
2248
ANY ONE TELL ME ABOUT THE BUILDING CRACKS
Last answer on 12/31/2020 2:31:49 AM. by S L Gupta (Civil Engg). Forum started by arun kumar sharma
3502
1968
Last answer on 5/20/2010 8:30:01 PM. by S L Gupta (Civil Engg). Forum started by sudhir
2130
is that crack making good treatment reliable
Last answer on 7/7/2010 8:53:52 PM. by S L Gupta (Civil Engg). Forum started by antoine vencatasawmy
2731
2339
1799
How to repair the suspension crack floor
Last answer on 2/4/2015 11:31:02 AM. by S L Gupta (Civil Engg). Forum started by BAURO
1599
1997
3370
2710
constraction details
Last answer on 1/1/2021 2:45:02 AM. by S L Gupta (Civil Engg). Forum started by ranvir kumar singh
3133
4292
Cracks in brick walls in 5th floor apartment
Last answer on 2/8/2021 8:45:31 AM. by singhvishal1689. Forum started by Raghu Kumar Akkala
2898
4137
1885
Do kitchen sinks made of Quartz as tough as stainless steel or do they crack i
Last answer on 7/17/2014 10:14:20 PM. by JAI PRAKASH. Forum started by neelam rathi
4137
5734
1591
How to renovate the broken staircase. please look the attachments.
Last answer on 4/25/2016 1:08:43 PM. by S L Gupta (Civil Engg). Forum started by chitta naik
1525
Cost for Polyurethene Grouting for Leakage from Flat Above
Last answer on 3/28/2015 6:24:30 PM. by JAI PRAKASH. Forum started by Unmesh
6880
2278
2295
cracks in walls
Last answer on 9/4/2013 12:14:18 PM. by S L Gupta (Civil Engg). Forum started by Gagandeep
2058
Cracks in my new house
3133
4035
2648
How To Repair Cracks
Last answer on 5/6/2010 12:31:22 AM. by . Forum started by suni dutt panwar
Which type of Damp Proof Course (DPC) is recommended for protection from cracks ?
The best DPC is of plastic membrane placed across the whole width of the wall to its full length
Which type of wall plastering is recommended for protection from the cracks?
To avoid cracks, Earthen Plastering is applied. Clay in Earthen Plasters is Hygroscopic (water absorbing). Earthen wal..
Surface
Importance
