Brick work
Sun Jul 26, 2015
nithin
Topic: Red brick/ Blocks / Aerocon brick
Can u share some advantages & disadvantages of
Red brick/ Blocks/ Aerocon bricks with respect to usage, cost, durability & strength
Mon Jul 27, 2015
In my view it is better to use FIRST CLASS BRUNT CLAY BRICKS as these are economical and easy to handle during construction.It is easy to make recess, to lay electric line and water supply line and easy to repair the cut and recess etc. These are also better for any type of inside and out side finishing on the walls.
Tue Jul 28, 2015
Red Bricks - Cheap and easily available.
3433
amit yadav
amit yadav
2874
FLYASH OR CLAY BRICK
Last answer on 12/3/2013 11:46:22 AM. by
Abhishek
2708
type of brick
Last answer on 12/5/2013 11:14:47 AM. by
neelam rathi
4179
GLASS BLOCKS / BRICKS
Last answer on 11/10/2021 8:22:17 PM. by
Girish
Girish
7513
Brick Advice Urgent
pmarple
pmarple
1863
Last answer on 1/5/2022 9:14:05 PM. by
sanjay agarwal
saradha
2836
Compound Wall Construction
Last answer on 11/20/2012 3:25:21 PM. Forum started by
honnappabr
13651
Last answer on 1/18/2022 1:46:41 PM. by
Bronx
honnappabr
3145
Last answer on 8/16/2013 1:12:41 PM. by
K S SHYAM SUNDER
3457
Last answer on 9/17/2012 8:35:35 PM. by
piyush
Kinley Tshering
5135
Use of Solid Concrete Bricks
aravind
Kinley Tshering
2992
2018
Last answer on 8/4/2011 2:42:26 PM. by
BEN
1366
Last answer on 7/28/2020 12:37:49 AM. by
vishal singh
2047
question
Last answer on 4/15/2013 12:34:12 PM. by
arpitbedi
2095
Red Exposed Brick
Last answer on 12/8/2014 10:03:59 PM. by
awdhesh
2350
Vikas
4056
Last answer on 7/26/2012 12:16:09 PM. by
sanjay kumar makhija
3669
wals
shabbir ali
3264
compound wall
Last answer on 7/20/2021 1:24:04 AM. by
Satish Pingulkar
21875
Last answer on 7/3/2020 11:10:01 PM. by
Sambasiva Rao Ravuri
3280
Bedroom Wardrobes information
Last answer on 7/3/2020 9:26:49 PM. by
Meenakshi
2246
Last answer on 5/15/2017 1:39:35 PM. by
mknmohamed
2206
Last answer on 5/2/2017 5:25:23 PM. by
pramod
1494
Last answer on 1/16/2017 3:10:03 PM. by
1965
Last answer on 12/6/2016 1:58:54 PM. by
1732
2224
Last answer on 11/3/2016 11:03:14 AM. by
atulbelokar
2523
1502
Last answer on 10/29/2016 2:54:11 PM. by
Er.S.K.Jain
1910
Brick or ACC block
Last answer on 10/7/2016 4:31:32 AM. by
gpeter
gpeter
2025
1653
Last answer on 9/13/2016 2:59:02 PM. by
1702
4687
Brick wall on RCC slab
Last answer on 1/27/2016 11:56:55 AM. by
rajiv sharma
2617
Last answer on 2/20/2015 6:00:27 PM. by
gurmeet singh
Brick Arches
Specification of Brick
Bricks Quality
Brick Pillar
Buying tips for Bricks
Buying tips for Brick Blast
