Home -> Forums -> Interior -> Home Improvement -> Refinish a Vinyl Floor
Thu Sep 25, 2014Total posts : 2
manish singhvi
manish singhvi
Topic: Refinish a Vinyl Floor
What can I use to refinish my 5 year old vinyl floor ?
Tue Sep 30, 2014Post  #1
Dear singhvi
EASY CARE STEPS FOR ARMSTRONG VINYL FLOORS
To keep the lasting shine and fresh feel of your investment for as long as possible, we recommend that you:
DO
  • Wipe up spills as soon as possible. Remove dried spills with Armstrong™ Once ‘n Done® Resilient & Ceramic Floor Cleaner.
  • Wash your floor occasionally with Armstrong™ Once ‘n Done® Resilient & Ceramic Floor Cleaner.
  • Use Armstrong New Beginning® Extra-Strength Floor Stripper for heavy duty cleaning on all products except Alterna.*
  • Use Armstrong Shinekeeper® Floor Finish or Armstrong Satinkeeper® Low Gloss Floor Finish to return your floor's original shine if it begins to dull over time.
* For Alterna non-grouted tile installations, use New Beginning for heavy duty cleaning.
DON'T
  • Use detergents, abrasive cleaners or "mop and shine" products - they may leave a dull film on your floor.
  • Use paste wax or solvent-based polishes.
  • Use a beater bar when vacuuming because it can visibly damage the floor surface.
  • Use highly abrasive scrubbing tools.
  • If you use grout with your Alterna™ floor, don’t use Armstrong New Beginning Extra-Strength Floor Stripper or other floor strippers to clean the grout or to clean your floor. Floor strippers will degrade the acrylic grout.
IMMEDIATELY AFTER INSTALLATION
  • Maintain room temperature at 65 degrees Fahrenheit for 48 hours after installation is completed. This assures proper curing, setting and bonding of products.
  • The adhesive under your floor needs time to thoroughly dry after installation. Therefore we recommend that you do not scrub or wash your floor for five days.
  • For vinyl sheet, allow the seams to seal for 8 hours after seam application. This will ensure the proper seam bond and a seamless finish. If seams are disturbed before they’re dry, permanent damage may result.
  • For vinyl tile, use a damp sponge, cloth, or mop to wipe off the Armstrong logo and 800 number printed on the face of the floor. Be careful not to wipe across any seams.
PROACTIVE PROTECTION FOR YOUR FLOOR
  • When moving appliances or heavy furniture, lay a plywood panel on your floor and "walk" the item across it. This protects your floor from scuffing and tears.
  • Use Armstrong Floor Protectors on furniture to reduce indentation. As a general rule of thumb, the heavier the item, the wider the floor protector needed.
  • Be careful with rolling casters. They can damage the floor. Therefore, we do not recommend them. If you choose to use them, the double wheel type are the best option.
  • Place a walk-off mat at outside entrances to reduce the amount of dirt brought into your home. We do not recommend the use of rubber- or latex-backed mats because the chemical (antioxidant) used to keep the backing from becoming brittle can permanently stain your floor. We suggest a nonstaining vinyl-backed mat or a woven rug that is colorfast. Most of these products are identified "colorfast" by the manufacturer.
Tue Feb 22, 2022Post  #2
Vaasku
Vaasku
Do not worry if the house has been in need of cleaning or something like that for a long time. You just need to give it more time or call people who understand this.
Home Improvement-Interior Questions (38)
2104
Vinyl Flooring
Last answer on 10/21/2010 8:22:02 PM. by priya. Forum started by Andrew Virgil
2120
Flooring
Last answer on 11/21/2011 10:18:40 AM. by solanzz. Forum started by Gagan Deep
1408
Are concrete flooring slippery?
Last answer on 6/1/2016 11:29:05 AM. by S L Gupta (Civil Engg). Forum started by Nations Construction
477
Vinyl flooring - yes or no? - A lot of people are using these floors now, but I
Last answer on 9/2/2021 5:44:48 AM. by CrySmile. Forum started by olii fill
1707
What are the important steps of maintenance after installation of blended marble vinyl flooring?
Last answer on 6/25/2014 1:43:17 PM. by S L Gupta (Civil Engg). Forum started by chandrapalsen
1922
2373
2468
1599
How much Marole required
3947
need for plan
2062
1951
please send me 55 feet by 58 feet plans,graund floor and first floor
Last answer on 4/29/2015 11:56:29 AM. by seema tyagi. Forum started by Hafiz Abdul
1769
2398
is it advantageous to buy flat with stilt 2 floors or stilt 4 floors
Last answer on 7/29/2014 12:12:50 PM. by S L Gupta (Civil Engg). Forum started by Jacob Alex
3163
plz send me vastu complaint floor plan for 2 floor plot having dimensions of 30"
Last answer on 2/21/2022 6:22:21 AM. by seema tyagi. Forum started by ashok
3382
2066
We have a Ground floor house already constructed some 15 years ago,and 2 floors
Last answer on 8/22/2013 10:36:36 AM. by S L Gupta (Civil Engg). Forum started by feroz khan patthan
3348
2390
2521
Introduction
1088
Home appliances
2370
2965
layout plan
2182
Window Curtains For Home
3426
Reg: Interior design software
4764
2720
Living Room Decoration Ideas
2240
2034
2212
floor tiles
797
Online dating
2543
4041
Paint vs Wallpaper
2528
Design for a pooja room
9541
Wall Putty and primer
Straight Drop Awnings
2754
Kids Room Theme
2019
sapty tank
Refinishing Hardwood Floors
Vinyl
Vinyl Flooring
Which are various types of vinyl flooring?
Two types of vinyl flooring such as inlaid and printed............
What are special types of flooring?
Special types of flooring--Linoleum flooring..............
Pool covers
At the end of the swimming season there is a hard need to to cover the swimming pools with pools covers. A pool cover i
Tips for maintaining Flooring
Proper maintenance of flooring is required to retain the beauty of floors and home as well. The flooring preserved nicel
Important steps of maintenance after installation of blended marble vinyl flooring.........
Swimming
