Home -> Forums -> Construction -> Start Construction -> Reg planning & construction of 5 storey building in 50x60 site in bangalore
Tue Jul 19, 2011Total posts : 2
Harsha
Harsha
Topic: Reg planning & construction of 5 storey building in 50x60 site in bangalore
Hi All,
Im new to this forum and Im amazed at the amount of information this website has to offer. Im planning to construct a 5 storeyed building with atleast 12 flats in it, in a 50*60 sq ft site in Bangalore. The flats range from 1 Bedroom to 3 bedroom flats. I have a host of queries regarding starting off with such a huge project. Has anyone in this forum implemented such a project before? Your inputs will be highly appreciated.
Before starting off, I would like to know the legalities involved in getting planning permission for a building with 5 storeys in Bangalore, Karnataka.
1) Will I need special commercial construction permission for such a venture? Will the premises be considered as commercial or residential?
2) Apart from clearance from water/sewage board, electricity board, muncipal council etc, what other approvals do I require for a 5 storeyed building with a plan for one elevator(lift)? Should I be overly concerned about fire exits and emergency exits?
The above are the questions on legal and approvals. Now I would like to know more about starting construction. I will obviously be hiring a contractor with experience in building multi-storeyed buildings for commercial builders. Now I dont want the contractor to leave me high and dry in the middle of the construction. Will there be any kind of agreement/contract between us which will be legally binding?
Also, Im looking for a good estimator/calculator application for construction projects like these. Is there any around? I looked at the GharExpert estimator which is excellent but I need something to plot for multi-storeyed buildings.
Thanks,Harsha
Wed Jul 20, 2011Post  #1
Dear Mr. Harsha,
I have seen your feed in GharExpert forums and read about query. Thank you for contacting GharExpert for Architectural and Interior services. For proceeding it further, just read about the GharExpert service given below:
Please look at the services offered by GharExpert:
A. Architectural Drawing Services – Drawings Only
A.1. Architectural Services:
Architectural service of the house which includes the following:
·         Floor plans
·         Basement drawing
·         Basement details and waterproofing solutions
A.2. 2D Elevation:
First Phase
·         Front Elevation
·         Rear/Side Elevation
·         Boundary Wall
·         Exterior Gate Design
·         Sections
Second Phase
·         Terrace plan
·         Internal details such as Staircase ,mumty etc.
·         Door / window Schedule
A.3. Structural Services:
This service will include the following:
·         Foundation details
o    Foundation Plan
o    Footing Schedule
o    Column Schedule
o    Detail of Columns and Walls with steel arrangement
o    Details of Plinth beam
·         Structural drawings showing the beam and slab reinforcement details.
A.4. Electrical Services:
·         Drawings showing the position of electric fan, exhaust fan, tube light, bulb, power plug and switches etc.
·         Position of inverter and electrical motor pump etc.
·         Layout showing the whole conduting and wiring network.
A.5. Plumbing Services:
·         Layout drawing showing the position of washbasin, sink, W.C. seats, shower, bathtub and overhead tank etc.
·         Plumbing drawings which will include the network of laying of the pipes.
A.6. Vastu Services:
For vastu plans, vastu experts work with our architect to make a vastu compliant plan. Further iterations would be done till construction completes.
A.7. 3D Elevation:
·         Front Elevation
·         Boundary Wall
For vastu plans, vastu experts work with architect to make a vastu compliant plan
B. Please Look at the packages we offer for Interior Design :
Our design portfolio will include the following drawings.
1.         Layout drawings.
2.         Wall elevations of all rooms.
3.         Ceiling drawings of all rooms.
4.         Flooring drawings of all rooms.
5.         Electrical layout drawings.
6.         Details wherever required.
7.         Wardrobe designs or storage drawings where ever applicable.
8.         Design specifications which will include the color options, texture styles etc.
9.         Toilet detail drawing for all toilets.
10.        Kitchen layout drawings
11.        Suggestions on type of furniture, furnishings and artifacts.
12.        Door and window details.
C. Detailed cost estimate It is a step by step calculation of the material and labor required to complete a construction project. This document is prepared after analyzing the architectural plan of the building and has all details about the cost and material involved. For example, it will give you the exact quantity of cement bags, bricks, sand, steel and other raw material required and the prices in your area.
We have service for the construction cost estimate which would give you the brick by brick cost calculation.  Our detailed cost estimate pricing is given below:
Up to 2000 sq.ft area= Rs.2.50 per sq.ft.
From 2001 to 5000 sq.ft area= Rs.2.00 per sq.ft.
From 5001 to 10000 sq.ft area= Rs.1.50 per sq.ft.
Above 10000 sq.ft area= Rs.1.00 per sq.ft.
We will take almost 15 business days to prepare the detailed cost estimate.
We will supply you the document containing step by step calculation of the material and labor required to complete a construction project. This document is prepared after analyzing the architectural plan of the building and has all details about the cost and material involved.
Everyone can save upto 10% of the construction cost which can be a saving of Rs. 50 to Rs.100 per square feet.
For preparing the detailed cost estimate, We need additional documents from you:
3. Which type of shutters and wood is being used for doors and windows? Would it be deodar wood, hollock wood, teak wood etc.
6. Do you have exterior elevation design and structural drawings provided by your architect?
GharExpert can provide you a detailed cost analysis for your project that will help you save a lot of money.
Please send me an email if you need more information. We always look forward to work with you.
Gunjan
09896245337
Mon May 21, 2012Post  #2
palas
palas
Post subject: i m new to this line
I am going to construct 20 nos. of 3 bhk flat measiuring 25 x 49 sq. ft. in each flat. can u please help me out to design the external elevation of the building with the low cost maintanence as well as proper cover for windows and ventilation from the rain and direct sunlight. please  he lp me out.
palash
804
2190
Last answer on 1/28/2014 12:26:43 PM. by S L Gupta (Civil Engg). Forum started by rakeshreddymandala
1787
Dear team, Construction for the residential multi story building is in progress
Last answer on 11/14/2015 12:34:24 AM. by JAI PRAKASH. Forum started by Satheesh
1889
Looking for a CIVIL consultant
Last answer on 11/14/2015 12:33:25 AM. by JAI PRAKASH. Forum started by Satheesh
2572
house construction plans for 20x30 site
Last answer on 7/4/2020 2:28:10 AM. by Amrit Bhagat. Forum started by ramu
1718
Need Valuate the building
Last answer on 9/4/2015 12:11:07 PM. by S L Gupta (Civil Engg). Forum started by Hanumantha
3624
Wall unit
3083
2006
2255
Sreel pillars(post)
4651
1875
my site is diagnoal with notheast in diagnally moved,is this site right for cons
Last answer on 1/29/2012 3:33:09 PM. Forum started by Ksreddy
5324
Setback or bylaws as per BDA
Last answer on 1/13/2011 7:17:31 PM. Forum started by ranjeeth
10178
1651
2062
building plan for 53 x 31 feet site
Last answer on 9/11/2014 8:03:06 PM. by seema tyagi. Forum started by Satish
1727
Want to construct commercial building in 3200sqft land.
Last answer on 10/8/2013 3:46:26 PM. by S L Gupta (Civil Engg). Forum started by sudheer
28822
latest price of building materials in bangalore
Last answer on 10/10/2010 12:44:43 PM. by rudresh. Forum started by manjuks
2557
Bye Law
3310
How to Design a Garage
Comparison
Earthquake
Preliminary
