Home -> Forums -> Construction -> Start Construction -> Regarding Construction Cost
Sat Oct 17, 2015Total posts : 4
Sagar Hande
Sagar Hande
Topic: Regarding Construction Cost
I am planning to built a house on my own plot. All the plan has been passed by the corporation. Now I am looking for contractor who will built a house.
My total construction (Including all stairs, balcony's) would be 1800 Sq.ft.
Plot Size - 50 x 40 ft (2000 Sq ft)
Ground Floor - Parking
1st Floor - Leaving, Kitchen, Mast. Bed, Dining and Pooja Room
2nd Floor - 3 Mast Bed
Leaving Room has a double height
I have approached some contractor and every one gave me different construction area calculation. Some said we will charge for total 3000 Sq. Ft. Some said it would be 4750 Sq Ft.
What all factors needs to be consider for calculating total construction cost
Sat Oct 17, 2015Post  #1
The charge has to be made on the covered Lantel area only not on the entire plot size.
Mon Oct 19, 2015Post  #2
Er.S.K.Jain
Er.S.K.Jain
You have different rates for your all three floors and the area covered by slab.
On ground you have parking which have area 1800 Sft so the GF area is 1800 and rate of construction go up to 65% to 70% of base rate.
On first floor you have double height in drawing room so the FF area is less than 1800 sft but additional cost required for double height portion in normal practice take area with double height portion and deduction in bill for double height portion up to 25 % to 30 % of base rate.
On Second floor their is 1800 sft area and charged extra for lifting which is up to 10% of base rate.
its better if you ask contractor to give final amount for construction as per drawing. and separate rate for extra items.
Tue Oct 20, 2015Post  #3
Check the detailed quotation for more clarification as its very confusing.
Tue Oct 20, 2015Post  #4
Dear Sagar
        Er Sh S. K. Jain give reply in detail.
First of all you are constructing your house through contractor on LABOR RATE OR THROUGH RATE basis. In the labor rate area have less importance.
If you have time than it is better to construct your dream home by arranging the material and on labor rate.
  If you are going for through rate than have detail estimate after that you are in better position to deal with the contractor.
 There are link for your help
http://www.gharexpert.com/articles/Start-Construction-1973/Gharexpert-can-save-you-money-during-construction_0.aspx
3597
6099
What is construction cost
3075
Qn regarding Cost Of construction
Last answer on 12/31/2020 2:00:00 AM. by S L Gupta (Civil Engg). Forum started by Ashwin Pai
4807
2353
6464
3384
what will be construction cost for a bunglaw at khandala, near lonavala
Last answer on 4/27/2016 3:10:29 PM. by S L Gupta (Civil Engg). Forum started by vaid
10177
1977
Supervision cost
2680
2536
1477
1783
23866
3362
cost saving in construction of house
Last answer on 8/17/2020 2:10:30 AM. by foro. Forum started by raviprakash
2745
11827
cost of rbc and rcc slab
5085
3309
2133
2059
