Home -> Forums -> Construction -> Raw Material -> Regarding Pitched Roof costing
Fri May 30, 2014Total posts : 4
RN Murthy
RN Murthy
Topic: Regarding Pitched Roof costing
Hi, My name is RN Murthy and I am a senior banker working for a NBFC based out of Bangalore. I am in deep distress after I started construction of my house with a contractor. I had to chose full material contract as I had no time to provide. I met one of my friend who is an Architect and based on his advise he suggested me a contractor and started construction work in Jan 13.
The disputes started around Sept 13 due to non disclosure of rates and not being transparent in pricing. We arrived at a agreement value of 128000/- per 10 sq(i.e. 1280/- per sft), this was a non negotiated price and basic material cost was specified and any differential would be paid by the owner. To this extent I felt they are transparent and moved ahead.
As per the elevation drawing there are pitched roof and pergolas constructed and the contractor demanded 1280/- per sqft for the pitched roof and pergolas apart from the regular constructed area. I argued with him was he was charging too much for just concrete and met the architect to settlement the matter. Even the architect said it costs the price of the area and I have to pay for it.
I did consult some of my other friends to confirm and everybody side he was taking me for a ride or cheating me. He has placed a bill of 900sft of extra which works to 12L.
This cost has led my budget go out of gear and not knowing what do to do. Please help me understand if these rates are genuine and will it cost 1280/- per sft for a pitched roof.
The roof is constructed on 2nd floor. Appreciate you advise and help to handle this better. I have attached a picture for your reference and you can spot the pitched roof on both side of the building.
RN Murthy - 7829112266.
Attachments: RNMURTHY NEW3.bmp on Fri May 30, 2014,&n
Sat May 31, 2014Post  #1
Post subject: Roof Costing
Hi Murthy,
Said to know all this, I m also a civil contractor, Always do paperwork.
The costing can be measured by the measuring the concrete roof for which he is asking extra. If there is no wall constructed then he has to give you discount but that is very minimum.
Mon Jun 09, 2014Post  #2
RN Murthy
RN Murthy
Hi Prakash, Thanks for your note. But how do I calculate the cost.
Mon Jun 09, 2014Post  #3
Post subject: Pitched Roof costing
Dear Mr. Murthy, hello..! For such type of problem ,start from the cost of construction of each floor i.e. Rs 1280/- per SqFf. and what are the "ITEMS" included in it. for upper floors mainly these are  1.walls up to 10' height ,2 casting of lintel band at 7', 3.Roof slab casting  4. Plastering in side and out side 5.fixing of Door & windows,6 Flooring 7. Painting work 8. Electrification work and 9.sanitary & Water supply work according to plan....for Pitched roof  and Pergola ...it requires a less no. of these "items" ...so  include cost of the Items ,that are actually constructed, especially the height of walls..these are less than 7' ,on 3rd floor...Kindly consult your Architect to make it correct or take help of other qualified Engineer or Architect...I am sure it will solve your problem...Regards..
Wed Jun 11, 2014Post  #4
Post subject: Regarding Pitched Roof costing
Taken the breakup of costing for the complete construction and delete the parts which u r not getting. Simple as that.
roofing on open terrace
3124
How to Construct Hip pitch RCC roof for my 35'X45' size G Floor
Last answer on 2/7/2016 10:33:10 PM. by JAI PRAKASH. Forum started by ringwang
1648
4649
2335
2650
2239
Last answer on 1/4/2022 11:02:33 PM. by S L Gupta (Civil Engg). Forum started by nagaraju kakani
6412
RCC Roofing Cost
Last answer on 12/11/2013 11:01:19 AM. by S L Gupta (Civil Engg). Forum started by Praveen Srivastava
1601
sir/madam give tell about loadbearing banhkam as for 8 room roof is an tata 12 f
Last answer on 8/8/2011 4:24:14 PM. by S L Gupta (Civil Engg). Forum started by megha jadhav
191902
2033
2614
Last answer on 5/26/2016 10:55:05 AM. by S L Gupta (Civil Engg). Forum started by Madhu Ranjan
1432
I am planning to build a cost effective house. I like to explore use of metal sh
Last answer on 12/8/2016 12:32:51 PM. by S L Gupta (Civil Engg). Forum started by sasi raman
2510
Tile roofing
Last answer on 1/13/2014 2:42:23 PM. by S L Gupta (Civil Engg). Forum started by sourabh
5086
11830
cost of rbc and rcc slab
3597
2805
i need an information regarding the minimum cost of a wall decor with painting..
Last answer on 8/4/2018 2:36:29 AM. by S L Gupta (Civil Engg). Forum started by anoo
3076
RCC roof
1971
Marriage hall construction
2537
Function Hall
4201
11105
2189
2038
Estimate
11123
3074
Steel
3039
use of tmt bar
1643
work turned out by labour
2457
estimate
1763
2993
3606
1943
Cost of Steel construction
1613
2136
READY MIX PLASTER
1866
2223
zero slump concrete
Cupola installation tips
Tips for cupola installation
Cooper
Asphalt
Asphalt Shingles Roofing
Wood
Wood Roof Shingles
