Home -> Forums -> Construction -> Start Construction -> Regarding Roof Load on Pillar
Sat Sep 26, 2015Total posts : 2
Amit Kumar
Amit Kumar
Topic: Regarding Roof Load on Pillar
I Need One More information.
If I am planning for a hall area (13 feet X 27 feet ), and putting the pillar with 16 mm TATA saria (4 No of saria). Please find the attached screenshot. Please consider the highlighted rounded area in image.
Please suggest it would be sufficient to carry the roof load of this area. Putting 7 no of pillar with 16 mm saria. My confusion is that the load of the hall will be easily carried out by this biller if I am putting 2 number of latak beam .
Additional information required : if I am planning for 4 no of 16 mm saria pillar than what should the size of pillar and what size of ring required for this piller.
Attachments: Image1.JPG on Sat Sep 26, 2015,&n
Sat Sep 26, 2015Post  #1
The plan is ok. plz go ahead. Size of beam 9x9.
Mon Sep 28, 2015Post  #2
Dear Amit
       The size and steel is designed by structural engineer by taking load on the pillar/ column. How ever for general use you should take the pillar / column size 12''x9'' with 6 no 16 mm dia bars and use cement concrete 1;1.5;3 ratio.
3610
3459
What is gap to maintain in Plinth/beam/Pillar/roof/Chejja
Last answer on 11/10/2016 5:26:49 PM. by S L Gupta (Civil Engg). Forum started by sam_m400
2054
2268
RCC roof on other than pillar
Last answer on 11/26/2015 3:34:20 PM. by S L Gupta (Civil Engg). Forum started by Binoy Rabha
4431
1764
2213
3941
3608
18435
10048
3129
Plinth beam at ground level
2695
4391
5692
12462
First floor construction
2239
Last answer on 1/4/2022 11:02:33 PM. by S L Gupta (Civil Engg). Forum started by nagaraju kakani
2758
Last answer on 8/26/2013 1:23:28 PM. by S L Gupta (Civil Engg). Forum started by ragha
2526
3312
2236
2717
2313
2061
Brick Pillar
Cooper
