Home -> Forums -> Construction -> Start Construction -> Reinforced brick wall construction
Tue Oct 11, 2011Total posts : 1
sunny420
sunny420
Topic: Reinforced brick wall construction
what is reinforced brick wall construction. How it is done...plzz guide me how it save money interms of concrete, and also it is a low energy consumed material when compared to concrete..
Fri Oct 14, 2011Post  #1
Post subject:
Dear sunny
      There are three type of reinforced brick wall construction.
  • Reinforced hollow unit masonry
  • Reinforced grouted cavity masonry
  • Reinforced pocket type walls
But in basement we use Reinforced hollow unit masonry wall in this Brick wall constructed on both side with a hollow portion in between two walls MS steel bars horizontally and vertically is placed and is filled with cement concrete. The other two option are not in generall use in India.
2153
1815
2993
2708
type of brick
3082
2876
1341
4057
9885
2417
9197
1511
11569
Brick wall and Lintel construction cost per SqFt
Last answer on 6/7/2015 1:27:14 AM. by JAI PRAKASH. Forum started by DD Gandhi
1797
2866
Bricks
3993
3792
2537
Civil Eng Stair Design
2537
3312
2236
2717
2313
2061
Brick Arches
