Home -> Forums -> Construction -> Raw Material -> Reinforcement details for ductility
Mon Jul 22, 2013Total posts : 2
shivakumar
shivakumar
Topic: Reinforcement details for ductility
sir,
Sir we are constructing an govt building in  Vapi Gujarath its comes under Seismic zone, so we providing an Fe500D(ductile) steel and  the 50% lapping of must be we have an single floor height is (3.4mts) so for that from basement floor Ist floor it may getting 7.8 mts ,Its not possiable to put such long rod so please give ur vauable suggestion for us.
                         Thanking you
Shiva kumar
Sr.Engg
+917818880602
Mon Jul 22, 2013Post  #1
Dear Kumar
             Your query is not clear. As for my opinion You want to know about lap in Steel bars.The lap should be as under
There should be no joints in steel bars used for RCC work. If it is necessary to use small length steel bars, proper overlap should be given.
The joints of bars should  be welded in case the diameter of bars is more than 36 mm. Overlapping of bars should not touch each other and they should be kept apart. Where it is not possible, overlapping bars should be bound together at intervals not exceeding twice the diameter of such bars with two strands of steel wires trusted tight. The overlap should be staggered for different bars. The length of overlap should not be less than 50 times the diameter of steel bar.
http://www.gharexpert.com/articles/Steel-1021/Type-Steel-Bars_0.aspx
http://www.gharexpert.com/articles/Cement-Concrete-1730/Mild-Steel-Bars-in-Cement-Concrete_0.aspx
Mon Jul 22, 2013Post  #2
Rudra Nevatia
Rudra Nevatia
Shivakumar:
Clause 7.2.1 of IS 13920:1993 states as follows:
Lap splices shall be provided only in the central half of the member length. It should be proportioned as a tension splice. Hoops shall be provided over the entire length at spacing not exceeding 150 mm c/c. Not more than 50% of the bars shall be spliced at a section.
So, it follows that, in the present case bars may be spliced within the central 1.7 m  of column. You may stagger splices within this length.
Rudra Nevatia
2575
Specification of ‘Plastering’
2382
1181
1406
1515
1261
6479
1982
1153
Does Indian Standards for construction specify the structure reinforcement requi
Last answer on 7/4/2020 2:00:43 AM. Forum started by Vineeth V
1842
2826
1793
Last answer on 4/13/2016 1:01:09 PM. by S L Gupta (Civil Engg). Forum started by ANKITA MADA
1510
TORSION REINFORCEMENT
Last answer on 4/15/2016 2:02:52 PM. by S L Gupta (Civil Engg). Forum started by ANKITA MADA
3320
2686
My House design
1514
2244
1196
How do Engineers calculate the Reinforcement needed for house. Is it possible to
Last answer on 9/25/2018 11:57:50 PM. by S L Gupta (Civil Engg). Forum started by Anu Mohan
1748
beam rod details
Last answer on 7/27/2016 1:14:29 PM. by S L Gupta (Civil Engg). Forum started by brigith jose dopson
3084
RCC roof
1977
Marriage hall construction
2546
Function Hall
4215
11132
2199
2043
Estimate
11134
3078
Steel
3042
use of tmt bar
1650
work turned out by labour
2467
estimate
1769
3021
3610
1946
Cost of Steel construction
1619
2142
READY MIX PLASTER
1867
2230
zero slump concrete
