Cement Concrete
Related to Sunken Slab
Thu Oct 22, 2015
SOUNAK SAMANTA
Topic: Related to Sunken Slab
This is regarding Sunken Slab for First Floor Bathroom.
1. First Sunken Slab is treated with water proof nd Net Cementing...
2. Then it is filled with light weight material -- chitlamm or boggu....A Outlet pipe has been kept by plumber to out the leaked water in sunken slab.
3. Then Concreting is done...
Now, Water Droplets are keep on coming through that outlet pipe when water is filled for Curing of Concrete... Is this normal or concrete is not properly done??
Best Regards,
Sounak, Scientistt, DRDO..
Fri Oct 23, 2015
In my view you should not worry about drop let of water, this will stop after laying floor on the concrete.
Fri Oct 23, 2015
SOUNAK SAMANTA
Post subject: Note of Thanks to Gupta Sir
I thank you very much for your valuable answer.
still I have few queries...
1. We have removed full water from top of concrete (which was kept for curing)... still droplets are coming out. When this droplet will stop? Is there is full of water inside sunken slab??
2. While Flooring with Bathroom Tiles, do we need to use any water proofing material in cement mortar i.e. Dr. Fixit?
I am eagerly waiting for your valuable feedback
Sounak
Sat Oct 24, 2015
Er.S.K.Jain
You lay lean concrete which is pores due this the sunken slab have filled with some water. which is produce droplet up to approx one month after that its dry.
After dry you provide flooring on top of concrete with water proofing material.
Sun Oct 25, 2015
Post #4
Do not worry as that will be cured by the process suggested above.
2148
Sunken slab
Last answer on 1/17/2021 5:51:16 AM. by
freekundli
Bhaskara
3673
sunken slab
Last answer on 7/3/2020 11:00:06 PM. by
sunken slab
Last answer on 1/5/2022 2:15:53 AM. by
amog
2244
hi sir,here is the toilet layout for a house im doing...is there a need for a su
Last answer on 4/12/2015 6:07:10 PM. by
amog
2893
Sunken toilet
Last answer on 6/16/2015 4:07:50 AM. by
manjula
2449
I intend to put non skid tiles at bath (Sunken Slab) at first floor. Please conf
Last answer on 1/23/2013 1:14:36 PM. by
shahidain
9087
Bathroom with no sunken slab
Last answer on 7/3/2020 9:35:17 PM. by
rinondavid
Swaroop
2144
i need the term related with damp proof and its treatment
Last answer on 8/29/2012 5:01:18 PM. by
abhijeet joshi
love related problem in agartala__ 91-8769373431 kala jadu specialist baba ji du
Last answer on 12/14/2024 1:59:59 AM. Forum started by
rupeshji
17
Last answer on 12/14/2024 11:35:46 PM. Forum started by
rupeshji
Last answer on 12/17/2024 12:41:38 AM. Forum started by
rupeshji
Last answer on 12/18/2024 10:31:39 PM. Forum started by
rupeshji
2930
Last answer on 10/5/2016 11:34:14 AM. by
arun
arun
23866
Can we construct toilet without sunken area ? If yes, how to do it.
Last answer on 7/4/2020 1:57:51 AM. by
GUNA
Kapil Singhal
2115
suppose i take all water pipes through sunken area along the length and breadth
Last answer on 7/23/2011 2:18:10 AM. Forum started by
D.Ramachandran
9893
Last answer on 9/19/2020 12:43:29 AM. by
shaik khaja nayab rasool
rishi
4065
premkumarlen
2865
Steel calculation
Vamshidharreddy
2174
give me siggestions related to concept?wat are the points kept in mind while des
Last answer on 12/31/2020 2:39:33 AM. Forum started by
richa
3469
Cost of concrete walls
Ar. Manoj Ralen
Ankur Kothari
1792
STP
Last answer on 5/18/2021 1:47:12 PM. by
Nijesh Ramraj
3106
Last answer on 12/31/2020 1:53:26 AM. by
N.S.BISHT
Pujesh Mallick
3651
Last answer on 9/17/2020 9:19:38 AM. by
Razi
4348
rate comparison
Last answer on 7/4/2020 2:15:33 AM. by
aammiitt
aammiitt
3203
Concrete Mixture
Last answer on 7/4/2020 2:11:26 AM. by
Ar. Manoj Ralen
Navneet Shahrawat
3142
sloping roof
Last answer on 7/4/2020 2:00:34 AM. by
ekonagu
2090
Last answer on 7/4/2020 1:58:38 AM. by
abdul
15805
Last answer on 7/3/2020 11:48:29 PM. by
Mohan
6469
Last answer on 4/5/2018 12:39:19 AM. by
Sanzana Hosen
2379
leakage in new slab
Last answer on 7/15/2017 3:57:04 AM. by
rajeev
milind
1527
Guide me
Last answer on 3/22/2017 12:35:27 PM. by
Subash
5118
Last answer on 1/25/2017 5:30:02 PM. by
vinod singh
2535
Civil Eng Stair Design
Last answer on 2/1/2016 1:27:20 PM. by
swarooppratap
2535
swarooppratap
1857
Last answer on 8/22/2015 7:13:59 PM. by
bala
1997
Concrete Hollow Block Masonry
Last answer on 7/2/2014 11:26:57 PM. by
s p kataria
2414
roof concrete
Last answer on 5/22/2014 1:50:02 PM. by
sakthi
3199
Ready Mix Concrete
Last answer on 10/7/2013 11:24:46 AM. by
sck
Reasons of dampness
Garden Path Ideas
