Home -> Forums -> Interior -> Bathroom Flooring -> Removal of cement grout from bathroom flooring
Sun Mar 23, 2014Total posts : 1
Mrs Francis
Mrs Francis
Topic: Removal of cement grout from bathroom flooring
There is a lot of cement grout on my bathroom flooring (between two tile0which makes my bathroom look very unfinished.  Please tell me how I can remove this out and also give my bathroom floor a clean look
Mon Mar 24, 2014Post  #1
If your home construction is going on. then tell the contractor to clean it at the time of tile fixing. use wet cloth or sponge to clean. once the cement is set and become hard, then it will be impossible to remove extra cement between joint.
Bathroom Flooring-Interior Questions (29)
55
91-7681982445 Online Jadu tona removal Specialist molvi Ji
Last answer on 7/5/2024 2:54:40 AM. Forum started by Miyan Akram JI
53
Last answer on 7/5/2024 2:54:42 AM. Forum started by Miyan Akram JI
58
Last answer on 7/5/2024 2:54:43 AM. Forum started by Miyan Akram JI
53
Last answer on 7/5/2024 2:54:47 AM. Forum started by Miyan Akram JI
54
Last answer on 7/5/2024 2:54:48 AM. Forum started by Miyan Akram JI
49
Last answer on 7/5/2024 2:54:49 AM. Forum started by Miyan Akram JI
51
Last answer on 7/5/2024 2:54:52 AM. Forum started by Miyan Akram JI
52
Last answer on 7/5/2024 2:54:54 AM. Forum started by Miyan Akram JI
57
57
Last answer on 7/5/2024 2:55:01 AM. Forum started by Miyan Akram JI
50
Last answer on 7/5/2024 2:55:04 AM. Forum started by Miyan Akram JI
53
Last answer on 7/5/2024 2:55:05 AM. Forum started by Miyan Akram JI
47
Last answer on 7/5/2024 2:55:06 AM. Forum started by Miyan Akram JI
48
Last answer on 7/5/2024 2:55:07 AM. Forum started by Miyan Akram JI
50
Last answer on 7/5/2024 2:55:08 AM. Forum started by Miyan Akram JI
54
Last answer on 7/5/2024 2:55:09 AM. Forum started by Miyan Akram JI
52
Last answer on 7/5/2024 2:55:10 AM. Forum started by Miyan Akram JI
51
Last answer on 7/5/2024 2:55:11 AM. Forum started by Miyan Akram JI
50
Last answer on 7/5/2024 2:55:14 AM. Forum started by Miyan Akram JI
1933
Sadrahalli
Last answer on 2/23/2021 12:45:32 AM. by sam_m400. Forum started by sam_m400
2519
Bathroom Flooring
Last answer on 12/31/2020 2:15:20 AM. by view interior. Forum started by vijay
3234
Bathroom tile cleaning
Last answer on 12/15/2020 8:22:53 AM. by leelindsey. Forum started by vandana
2243
1849
Bathroom-water proofing and tiles
Last answer on 12/8/2014 10:03:14 PM. by JAI PRAKASH. Forum started by bhr2014
1781
My house is under construction and i have to go for plumbing therefore i want to
Last answer on 9/17/2014 10:59:54 PM. by JAI PRAKASH. Forum started by Avinash Sharma
1914
acid wash
Last answer on 3/24/2014 1:45:01 AM. by Purvi Panchal. Forum started by Mrs Francis
2363
2168
Hi, I am planning to put Morward or Agriya marble in my house. Size of the
Last answer on 4/9/2011 7:22:58 AM. Forum started by Rajnish Gupta
1715
Appreciated if i could get some advice on using granite stone and the shade, sin
Last answer on 9/23/2010 11:58:18 PM. by Ar. Manoj Ralen. Forum started by cruz
What preparations for base are recommended for terrazzo tiles flooring?
Preparation for base:- It is one of the most important steps to satisfy the tile installation. Sub flooring should be ..
Bathroom Pictures
Bathroom Lighting
Bathroom Accessories Part-4
Bathroom Decorating Ideas
Using
