Home -> Forums -> Construction -> Start Construction -> Remove ground floor in house without columns
Fri Jul 27, 2012Total posts : 1
Ramesh
Ramesh
Topic: Remove ground floor in house without columns
I am leaving in a G+1 house. This is without columns. Ground floor was constructed in 1992 and First floor in 2000. We dont have ample parking space and ground floor house is old fashioned.
Is there any way to put columns(pillars) to support first floor and remove ground floor, so that i can make some parking space and go for construction of second floor. Is it possible?
Ramesh.
Fri Jul 27, 2012Post  #1
Dear Ramesh
         It is possible to construct new RCC column and put/ construct beam under first floor by giving necessary supports. when beam is fully cured and able to take load then can remove the ground structure.BUT DO NOT make this without the consultation of structural / civil engineer, who will give design of column, beam, MS steel in column and beam and give some instructions about how to handle the work at site.
3002
3016
10325
900 Sqft column required
Last answer on 7/21/2021 11:11:14 AM. by S L Gupta (Civil Engg). Forum started by Shivaraj
3304
3947
2579
1661
Respected sir, Please upload 29×66 south facing plot ground floor d
Last answer on 2/12/2022 12:31:01 AM. by S L Gupta (Civil Engg). Forum started by Vikram parihar
1374
3308
3680
24feetby 81feet house plan ground floor ,dabal parking, one shop.
Last answer on 7/3/2020 11:24:29 PM. by S L Gupta (Civil Engg). Forum started by Pramod kumar
2657
Please suggest house Map for ground floor plot Size 10x22.5 feet
Last answer on 8/4/2016 5:21:11 PM. Forum started by Gopal Upadhyay
2276
I need 30x50 feet east facing ground floor house plan with 3 bedrooms
Last answer on 7/11/2016 1:48:57 PM. by Amrit Bhagat. Forum started by ananddv3
2330
2490
plan a corner house ground floor size 30'x50', south
Last answer on 1/19/2011 4:55:47 PM. by sabina vanjani. Forum started by bharat
15666
3650
I want to built a house with stilt,ground floor
Last answer on 8/30/2021 6:11:55 AM. by S L Gupta (Civil Engg). Forum started by venkatesha
1887
Rework required on blinth beam.
Last answer on 10/1/2013 10:53:53 AM. by S L Gupta (Civil Engg). Forum started by ananth
2572
2076
We have a Ground floor house already constructed some 15 years ago,and 2 floors
Last answer on 8/22/2013 10:36:36 AM. by S L Gupta (Civil Engg). Forum started by feroz khan patthan
2482
3308
3321
4450
4026
2249
2725
4235
5209
2396
2322
2025
2463
2142
3216
2075
12547
2190
2031
2752
Preliminary
Pool Pumps
Surface
Carpet
Carpet Cleaning Tips
