Home -> Forums -> Construction -> Start Construction -> Renovation of common wall structure
Tue Aug 09, 2011Total posts : 3
Rishiv Dev Garg
Rishiv Dev Garg
Topic: Renovation of common wall structure
i am looking forward to complete renovation of my house. my house is around 40 years old and the common walls with neighbors had been built with mud and bricks as in old times. now facing the problem of water proofing, as i plan a master bedroom with the common wall, what is the best method to water proof the common wall and build its strength. i have come up with an idea of building a complete concrete wall 75mm thick from the DPC. kindly suggest better options.
Thu Aug 11, 2011Post  #1
Dear Rishv
     From the contents send by you it is not clear that water leakage is from your neighbours house or from your roof.
Fri Aug 12, 2011Post  #2
Rishiv Garg
Rishiv Garg
Dear Mr. Gupta
Thank you for your reply
as both our houses are around 40 years old, the common wall doe snot have any proper concreting on the base i.e. DPC. Water proofing is required  to be done from the the base of common wall and in vertical direction of common wall as the neighbors have their kitchen with it.the size of our common wall is app. 80ft with single story construction in mud and bricks and the second story is proper cement & bricks. our new construction has to come upto 45ft. till 1st floor. kindly suggest best possible method for water proofing from the base of structure, and also to strengthen the common wall with waterproofing it too.
my new construction area is completely clear till base ans has to be rebuilt from the first step as a new building.
Tue Aug 16, 2011Post  #3
Dear Rishv
       From the contents sent by you I am in view that you are constructing a new potrtion about 45' in length. You should follow all construction procedure including laying horizontal damp proof coat with cement concrete 1;2;4 with two coats of hot bitumen and polythin sheet.For more details about dampness and water proofing you should visit the websitegharexpert.com construction section where in safety a lot of material you will find about dampness and water proofing in dampness sub section.
As you asked about old common wall, then it is necessary to know that your neighbour is also want treatment and he is ready for dismenteling and new construction then after giving both side supports you may construct new wall with DPC. Otherwise do the plaster on the wall and lay KOTA stone under the wall at the place of DPC by making cavity inthe wall in 2 to 4 feet long streches in the full width of the wall with the consent of your neighbor.
2788
what happens common stair case comes to north or northeast wall of the flat?
Last answer on 5/27/2013 12:51:23 PM. by GULSHAN RAI GULATI. Forum started by gantag
2329
purchased flat 10 yrs oldd , advise for renovation ,
Last answer on 7/4/2020 2:47:02 AM. by S L Gupta (Civil Engg). Forum started by alakh nath tiwary
2256
1837
Construction - Interiors - Renovation
Last answer on 7/13/2017 12:28:47 AM. Forum started by JAI PRAKASH
1971
Bathroom renovation tips
Last answer on 2/24/2022 7:21:19 AM. by Messi1999. Forum started by Kirow44
2525
2330
2088
all designs ok but common people like me cannot afford
Last answer on 7/25/2010 1:46:59 PM. by ranjeetsaini. Forum started by Abdul Rasheed Alungal
a plot of 15×60 two room set + drwing+ lobby
Last answer on 5/13/2016 10:15:46 PM. Forum started by Sanjay arora
1564
i am constructing first floor. i want to keep common wall to neighbour be 4.50 i
Last answer on 1/10/2015 12:24:55 PM. by S L Gupta (Civil Engg). Forum started by ashok
2115
Structure proof checking
2212
1857
how to see vasthu for street houses with common walls...most of my Qs remain to
Last answer on 8/30/2011 12:16:12 AM. Forum started by D.Ramachandran
2629
Looking for engineers in Bangalore, with focus on home renovation with cost effe
Last answer on 6/17/2013 11:59:44 AM. by Anupam Anurag. Forum started by MADHUSUDHANAN AR
1918
How do I clean cement and brick dust created
Last answer on 8/27/2021 7:09:02 AM. by S L Gupta (Civil Engg). Forum started by Satvinder kaur
2212
floor tiles
1748
1401
Need to add structure support to North wall
Last answer on 9/19/2021 6:04:43 AM. by Michaell. Forum started by Geoffrey Marsh
4040
Cost Comparison Between Brick Wall & Concrete Frame Structure
Last answer on 7/3/2020 11:40:50 PM. by PR Jawahar. Forum started by PR Jawahar
3312
2312
Tips for Lighting your Kitchen
Lighting plays an important role in setting the ambience of the room. Consider the amount of available light when your c
Earthquake
Kitchen design mistakes
Canvas
Canvas Wall Art
