Renovation of old house
Sat May 18, 2013
chandrakanth
Topic: Renovation of old house
I have a 3 BHK house in 30x50 site constructed without pillars. The portico is of 10ft x 14ft (10 is length, 14 is width). I have problem for car parking as at least a 13ft Length would have been better.
I am planning to modify my house. The portico would be now 13ft x 30ft.
So I am need pillars (columns) to support this huge span of RCC slab.
Also I am keen to know is it possible to now put pillars from base of foundation may be by drilling etc for the rest of the house?
Chandrakanth
Sun May 19, 2013
painterssanjose
good
Mon May 20, 2013
Anupam Anurag
Post subject: Column Options
Dear Mr. Chandrakanth,
You could also consider the option of putting steel columns to support the weight of the slab rather than the conventional concrete columns.
Anupam
9632064394
Mon May 20, 2013
Dear Chandrakanth
First of all prepare the modified drawing i.e. addition and alteration drawing according to your requirement with the help of architect.
The 2nd step is contact any structural engineer who can see the possibility of change after visiting the the site of your constructed house and instruction or explore the possibility of changes made in old construction.
In my view this is the proper way to make addition and alteration without compromising the strength of the building.
By putting columns without proper planing serve no purpose.
Fri May 24, 2013
Post #4
chandrakanth
Gupta Sir, thanks for your valuable suggestion and time.
I see that you are active participant in this site and provide your expertise to the community. Keep up the good work.
2906
Last answer on 6/16/2012 4:17:41 PM. by
MUKESH MISHRA
2301
New Home
Last answer on 7/26/2013 4:14:40 PM. by
neelkanth purohit
4623
Last answer on 11/4/2021 8:45:13 PM. by
Prem Kant Mishra
2312
Last answer on 6/7/2017 12:17:49 PM. by
Prem Kant Mishra
2383
Last answer on 7/3/2020 11:25:42 PM. by
Rishiv Garg
4539
24x60 west facing old home renovation Idea
Last answer on 7/3/2020 11:25:30 PM. by
rajeev
2307
purchased flat 10 yrs oldd , advise for renovation ,
Last answer on 7/4/2020 2:47:02 AM. by
alakh nath tiwary
1819
Construction - Interiors - Renovation
Last answer on 7/13/2017 12:28:47 AM. Forum started by
Bathroom renovation tips
Last answer on 2/24/2022 7:21:19 AM. by
Messi1999
Kirow44
2755
Improvisation of Housing Board House
Last answer on 8/17/2012 12:16:55 PM. by
MUKESH MISHRA
6802
Kitchen Ventilation
Last answer on 1/19/2022 2:55:03 AM. by
sugantha
sukamalroy
2760
I have purchased a resale 1BHk 453 sq flat recently, it south west facing ,kitch
Last answer on 7/16/2011 7:57:18 AM. by
Nitien Parmar
kishor
2909
Last answer on 11/8/2011 11:00:36 AM. by
timm todd
3304
Last answer on 5/1/2012 11:09:41 AM. by
pankaj sharma
1884
I am doing renovation of my home, want to place new tiles. shall i remove old t
Last answer on 7/3/2020 11:21:27 PM. by
NIRAV SHAH
1767
Tiles
Last answer on 12/10/2015 11:38:02 AM. by
NIRAV SHAH
2779
Sir,I am plaing to constuct my house in the old city Amritsar .The size of the p
Last answer on 12/26/2011 7:49:20 PM. by
shefali
jasbir
2777
how much will a flat sell without approval if its like 17 years old with 850sqft
Last answer on 3/6/2018 4:03:32 AM. by
anandrao
anandrao
2671
How to Paint Old Furniture
Tips for Lighting your Kitchen
Lighting plays an important role in setting the ambience of the room. Consider the amount of available light when your c
How to design a house on theme
Theme designing is slowly but steadily picking up steam. Designers today are very particular about the 'idea' behind a s
Environment Friendly Houses
