Wed Apr 25, 2012Total posts : 0
NV MANI
NV MANI
Topic: Repair of underground Water storage sump
Dear friends,
The underground sump (11000 litres) at my house receives drinking water supplied by city's metro water supply.
Unfortunately it is noted recently that the water inside sump is seen blackish and contaminated by getting mixed with outside drain water,probably water getting entry through the tree roots.
The roots from nearby tress have penetrated through side walls of water storage sump.The use of sump is therefore discontinued and the incoming valve is kept closed.
T
he top concreted floor is paved with tiles.The manhole to enter the sump is small to assess the nature and exact extent of damage. Moreover there is no  visibility even if inspection lamp is used.
It is practically difficult to inspect the defect and the only option could be to cut open the top concreted portion with flooring
(6" thickness) which is quite expensive and time consuming.
Shall be very thankful to receive advice as how the sump can be repaired and restored at least expense?
N.V.Mani.
5734
3370
5056
13539
3499
3080
Last answer on 1/2/2021 5:22:54 AM. Forum started by NV MANI
3119
2483
2187
2792
Last answer on 7/3/2020 11:53:31 PM. Forum started by mamta
2149
10066
cost estimation of water storage sump tank
Last answer on 9/26/2010 5:48:55 PM. by sathish. Forum started by manjuks
2043
Underground Water storage
40519
5462
Underground water sump
Last answer on 2/27/2015 11:50:23 AM. by revadi. Forum started by hb
1996
Hi. I have built a Fresh water underground sump in the South east corner of the
Last answer on 3/1/2011 3:05:47 PM. by Mohini Sharma. Forum started by m naveen
2374
underground water sump
Last answer on 9/10/2021 2:04:05 PM. by JAI PRAKASH. Forum started by prashanth a
913
Sir, I have a 6500 litres 10 year old brick-plastered underground water sump. It
Last answer on 7/3/2020 10:58:35 PM. by S L Gupta (Civil Engg). Forum started by Shivakumar
15
17
Vastu for Water Tank
How To Repair Cracks
Kitchen Storage Ideas
Garage
Garage Organization
Garage has become the storage solution for the house. There is need to have proper garage organization to keep it clut..
Clutter
Clutter Free Bathroom
Make your bathroom clutter free and organized using storage solutions. You can create storage spaces in walls, under ..
Storage
Storage Solutions for kids Room
Kids require a lot of storage space to place their toys and playthings. Proper storage ensures safety to the kids as c..
