Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> Replacement or modification Of AC ROOF
Tue Feb 16, 2016Total posts : 2
bipin karekar
bipin karekar
Topic: Replacement or modification Of AC ROOF
we want to replace or modify our existing AC sheet roof, also we want to do POP work on celling from inside. our existing home do not have any RCC Column, so please let us know possibilities of modification of Roof and if it is possible please let me know competitive quotation.
Wed Feb 17, 2016Post  #1
      In my opinion it is better to contact any civil engineer or contractor of your city.
Sat Mar 05, 2016Post  #2
Please contact the team.
1316
Last answer on 3/5/2016 9:24:10 PM. by JAI PRAKASH. Forum started by bipin karekar
18382
2347
How to Maintain Air Conditioner?
Last answer on 6/29/2021 4:36:51 AM. by DavidFlores18. Forum started by V K GUPTA
3816
Please see my proposed house plan and suggest if any modifications needed
Last answer on 7/4/2020 12:21:30 AM. by Aman aggarwal. Forum started by Vinod
3077
Regarding any modification in plan as per vastu
Last answer on 8/1/2013 11:26:06 AM. by S L Gupta (Civil Engg). Forum started by Dipesh
8190
Last answer on 7/3/2020 9:42:30 PM. by Beenu Phogat. Forum started by Prabhakar
8420
Roof Beam crack
1915
Outdoor unit of Airconditioner
Last answer on 9/18/2013 2:47:37 PM. by arnoldgibson2. Forum started by Purvi Panchal
2275
Ac and Electrcial
2850
4154
AC in main hall opening to kitchen
Last answer on 12/7/2011 5:34:44 PM. by Mostafa Atef. Forum started by Chits
20667
Heat reduction in the top floors
Last answer on 3/15/2011 10:12:45 PM. by Rohan Jaacob. Forum started by Dr. Tiwari
12251
3980
Roof leakage
2850
2158
1837
1791
2371
Roof construction
5811
3792
9885
2670
4628
4143
2865
5006
3656
1865
2800
2610
2373
2462
2638
1807
3608
6254
Central
Central Air Conditioner
Central air conditioners are good option for big houses or large building. And proper functioning of central air condi..
Air
Air Conditioner AC: Tips before buying Air Conditioners
Check out GharExpert buying guide for Air Conditioners AC so that you could know about different types of Air conditio..
Cooper
Asphalt
Asphalt Shingles Roofing
