Reply to Roof Concrete Strength
Mon Feb 24, 2014Total posts : 7
Jahankumar
Jahankumar
Topic: Reply to Roof Concrete Strength
Dear Navneet Jharia & S L Gupta Sir
Thank you very much for your Kind & Useful Reply of  regarding Roof Concrete Strength.
1)Main Rod Dia 10mm at 6" C/C with Cranking
2)Distributor Rod  Dia 8mm at 8" C/C
3)Roof Beam Dia 12 mm -5 Nos with Center Cranked & Height 12" Including 5" Roof Slop.
4)So Roof Beam Height (12"-5") = 7"
5) It has 16' x 16' Hall. So Two way Slap were done with Concealed Beam of Dia 16 mm -4 Nos at Middle.
6)All above are verified by taking photos with Measurement by Measuring Tape.
7) But Regarding concrete Strength , I have doubt that it will come between M15 (15 N/mm^2) to M10 (10 N/mm^2) by Reducing Cement by Builder.
8) How to check concrete Strength any conventional method  whether M15 (15 N/mm^2) or  M10 (10 N/mm^2). Suppose If it is between M15 (15 N/mm^2) to M10 (10 N/mm^2) , what is the way to improve the concrete Strength above M15 (15 N/mm^2).
9) Can we increase concrete Strength by Inner Ceiling Plastering ratio of 1:3 by Two Layering (or) using Admixture like Dr Fixit etc.,
10) Because Inner Ceiling Plastering  is not started yet.
11) Any Instrument is there to find whether it is M15 (15 N/mm^2) (or) M10 (10 N/mm^2)??
12) Also Weathering Proof is not started yet. Can we increase Ceiling Strength by  doing some modification at Weathering Proof.
Waiting for Your kind Reply
Jahankumar
Wed Feb 26, 2014Post  #1
Dear Jahankumar
           The way to find out the cement concrete ratio is that take sample of concrete from slab and send it to the lab. who after analysis give the result of concrete mix according to ratio used.
As stated already,  You should take help of any civil engineer, who can see the slab personally and check it by chiseling and hammering and also see the  span of the beam and slab. There is no use to add any extra concrete layer to the old concrete slab it will not add any strength but with extra concrete increase the load on the slab which  is unnecessary.
        A good cement plaster 1;3 ratio also give some additional strength to some extant only.
Wed Jun 26, 2019Post  #2
          Thanks for visiting the site.
Thu Feb 20, 2020Post  #3
Mon Feb 24, 2020Post  #4
Tue Feb 25, 2020Post  #5
Mon Oct 25, 2021Post  #6
Zainab Pollard
Zainab Pollard
best lov this
Mon Oct 25, 2021Post  #7
Zainab Pollard
Zainab Pollard
Post subject: dfvfd
vdvzfdvfd
2415
roof concrete
2414
2354
laying of roof
2108
5487
Roof Slap & Roof Beam
Last answer on 7/4/2020 2:23:44 AM. by S L Gupta (Civil Engg). Forum started by Jahankumar
2262
id like to know...is this paint or is this whole effect on the roof,given by a f
Last answer on 5/5/2011 5:50:43 PM. by P. Panchal. Forum started by amina
1067
2028
1700
My House is 10 years old and my Existing Concrete roof in Hall area started to p
Last answer on 4/5/2018 12:46:08 AM. by S L Gupta (Civil Engg). Forum started by soundar
6467
2993
3143
sloping roof
2596
What are the size available What about strength of main door price details
Last answer on 11/18/2013 3:35:39 PM. by S L Gupta (Civil Engg). Forum started by padma
2153
2015
stair case
Last answer on 8/16/2013 4:32:36 PM. by S L Gupta (Civil Engg). Forum started by SCK
11247
CURING ON ROOF CONCRETE
Last answer on 3/19/2014 10:26:34 AM. by Ahmed. Forum started by K Umapathi
2691
Want to know the Strength of the Roof Slab
Last answer on 3/8/2011 5:41:21 PM. by S L Gupta (Civil Engg). Forum started by Sambasiva Rao Ravuri
9197
23
27
Concrete Mix Ratio
Cooper
