Tue Feb 19, 2019Total posts : 2
Ravi
Ravi
Topic: Reply urgent. Regarding 4.5 inch wallHi Everyone,We have constructed 4.5 Red bri
Reply urgent. Regarding 4.5 inch wallHi Everyone,We have constructed 4.5 Red brick wall on 5 inch RCC (2 way slab), there is 12x9 inches horizontal beam passing 3 feet away from constructed wall and 18x9 inch vertical beam passing through wall.Now, wall height is 10 ft and width is 27 fts and has one door frame and one window 4x4 height.Is that safe?Thanks,Ravi.
Tue Feb 19, 2019Post  #1
           Do not worry it is safe.
Thu Feb 21, 2019Post  #2
Ravi
Ravi
Thanks for you prompt reply sir,
Beam is not exactly under the wall it is 3 feet away from constructed wall and I hope it is safe.
Thanks,
Ravi
outside side wall with 4.5 inch width is suggested or not ? will it cause seepag
Last answer on 7/4/2020 2:24:25 AM. by JAI PRAKASH. Forum started by ashok
8110
Wall on roof slab with no beam underneath
Last answer on 9/29/2020 11:34:24 PM. by S L Gupta (Civil Engg). Forum started by Joydeep
2331
beam load
Last answer on 9/16/2014 11:08:18 PM. by JAI PRAKASH. Forum started by rishabh
1652
Last answer on 7/3/2015 3:57:17 AM. by JAI PRAKASH. Forum started by sandeep yadav
8820
Last answer on 7/3/2020 10:16:59 PM. by JAI PRAKASH. Forum started by sandeep yadav
2519
1170
3342
Column footing size
Last answer on 7/4/2020 2:00:01 AM. by S L Gupta (Civil Engg). Forum started by Pooja
1710
want to put bath space seperators to seperate the shower space whuch is 4.5 by 3
Last answer on 9/12/2011 10:13:27 AM. Forum started by NAGIR REDDY
2815
doors on 4.5"partition walls
Last answer on 5/17/2010 7:19:02 PM. by Ramkumar G Krish. Forum started by mohan
4143
3303
3644
Last answer on 10/11/2020 7:16:16 AM. by Amit Hasija. Forum started by disha gupta
2511
Last answer on 5/20/2010 8:45:36 AM. by Dhananjay. Forum started by shivprasad
4575
STEEL BARS IN 4.6 INCH WALL
Last answer on 12/31/2020 1:56:26 AM. by pooja. Forum started by pooja
1208
Hi,Can you please tell me the cost of pillar with following dimensions 9inch * 9
Last answer on 12/17/2015 2:44:27 PM. by JAI PRAKASH. Forum started by Kalyan
8850
Last answer on 10/15/2014 1:52:38 PM. by SANJAY DUSANE. Forum started by Ambuj
1366
2304
Electrical Wiring
Last answer on 5/16/2013 12:22:40 PM. by S L Gupta (Civil Engg). Forum started by Unnikrishnan
15
17
Living Room Color Schemes
Paint Colors impart a beautiful effect in your every room if chosen perfectly. But sometimes the excessive use of bold..
