Home -> Forums -> Construction -> Start Construction -> Require inputs
Require inputs
Wed Nov 19, 2014Total posts : 2
vijay
vijay
Topic: Require inputs
Hi ,
I want to start the house construnction in bangalore. The site measures are as follows and Total site is 1470 Sqft.
East to west - 35 Feet
North to South - 42 Feet
Road is on North side
Want to build G + 1
and In ground flor leave to parking to park 2 cars and 4 bikes + 2 BHK ?
In 1st Floor  2 BHK with spacious hall and dining.
What is the current construction cost in bangalore Per SQFT including material.
Can you pleaes provide the approximate cost of construciton for the above requirement for medium quality and high quality.
Thnaks,
Vijay
Wed Nov 19, 2014Post  #1
In average quality it will cost u around 40 lac's and in good it will cost u around 50 lac's. All inclusive.
Wed Nov 19, 2014Post  #2
vijay
vijay
TThanks jai Prakash
4996
Input required on Basement parking
Last answer on 7/20/2012 4:07:42 PM. by S L Gupta (Civil Engg). Forum started by vinay
2213
Last answer on 12/14/2010 7:35:48 PM. Forum started by Rakshit
1940
2035
Dear Gupta sir,Can you please suggest the detailed specification for a good foun
Last answer on 5/8/2013 12:14:58 PM. Forum started by nithun
2019
COST DETAIL REQUIRED
Last answer on 12/24/2013 11:43:24 AM. by S L Gupta (Civil Engg). Forum started by ANNA.B
2276
2400
ineed plan and elevation and 3ddrawings.how much required
Last answer on 4/4/2014 2:07:38 PM. by S L Gupta (Civil Engg). Forum started by subramanian
2004
Required PVC Wooden Flooring
Last answer on 10/18/2013 3:52:51 PM. by S L Gupta (Civil Engg). Forum started by Krishna Equytech
2322
2059
how much green paint required in 1sqm
Last answer on 7/8/2011 8:24:30 AM. by Abrar Ullah. Forum started by sherab tenzin
3166
2550
Tips for Varnish
Last answer on 3/17/2010 12:38:44 AM. by S L Gupta (Civil Engg). Forum started by vinay meghani
2813
Last answer on 12/31/2020 2:51:38 AM. by S L Gupta (Civil Engg). Forum started by SHAILESH
2448
Last answer on 8/6/2011 2:32:51 PM. by sabina vanjani. Forum started by nita
3044
Last answer on 8/18/2011 6:51:51 PM. by prasadtvp. Forum started by chella earnest
2422
WE REQUIRE TILES DESIGN
Last answer on 7/8/2020 12:24:20 AM. by S L Gupta (Civil Engg). Forum started by JAGDEO PANDIT
2049
PVC windows
1653
Last answer on 7/3/2015 3:57:17 AM. by JAI PRAKASH. Forum started by sandeep yadav
8820
Last answer on 7/3/2020 10:16:59 PM. by JAI PRAKASH. Forum started by sandeep yadav
3312
2236
2717
2313
2061
