Home -> Forums -> Construction -> Layout and House Plans -> Residential Structural needs
Tue Oct 04, 2016Total posts : 1
Padmanabhan
Padmanabhan
Topic: Residential Structural needs
Dear Guptha sir,
I have the plot of 44 x 18 feet. I want build first floor and keep ground floor as parking area.
1. Can you tell me no. of columns required with column size and size of steel and no. of steel to be used?
2. Beam size and size of steel and no. of steel to be used?
3. What would be the labour cost in coimbatore area ?
4. If i want to construct 9 inch wall between two column of slab size of 4.5 inch is it safe ? or any beam to be made between two column and how far from one column is good ?
Wed Oct 05, 2016Post  #1
       It is better to get structural design. The tentative nos of columns may be 8 to 10 nos with 12''x12'' size with at least 8 nos 16 mm size MS Steel bars.
3721
11692
2048
I'M IN NEED OF MS WORKSHEET FOR STRUCTURAL DESIGN
Last answer on 8/24/2021 2:39:40 AM. Forum started by martin kevin red
2633
Structural Design
Last answer on 1/15/2022 3:01:21 AM. by Anthony Lofu. Forum started by ajay
963
Total area 485 sq yard g 31. Shop 8-9 2. Hotel reasturant 3. Room (9) 4. 3 bh
Last answer on 2/21/2021 12:19:24 AM. by S L Gupta (Civil Engg). Forum started by vinay
3180
Last answer on 3/14/2021 11:13:22 AM. by S L Gupta (Civil Engg). Forum started by venkatesan.pt.
9363
2567
roof of a building
Last answer on 7/3/2020 11:28:49 PM. by S L Gupta (Civil Engg). Forum started by sujata
2971
i need structural details and estimation for 150yd plot
Last answer on 8/17/2012 11:36:21 AM. by Gunjan Utraja. Forum started by gangula
6162
i want structural design of staircase in area 3.00mx 2.20 m
Last answer on 5/3/2014 7:45:54 PM. by Navneet Jharia. Forum started by sudipta das
2149
how to read structural drawings//Basic steps??
Last answer on 8/27/2015 6:43:26 PM. by JAI PRAKASH. Forum started by Maryanne Robynn Delana
3259
Need Residential Civil contractors in Faridabad, Haryana
Last answer on 2/3/2011 3:00:16 AM. by Archit Jain. Forum started by Archit Jain
4703
want a map/design for 40*58ft residential plot thanks
Last answer on 7/3/2020 11:20:54 PM. by jasmer singh. Forum started by rameshsingh
2338
I want a residential home design low estimate
Last answer on 4/23/2013 11:32:19 AM. by S L Gupta (Civil Engg). Forum started by Dipankar Gharami
3451
how to line out work to residential building
Last answer on 7/4/2020 2:18:55 AM. by S L Gupta (Civil Engg). Forum started by patil kiran
2477
east facing residential house plan for double bed room with vastu required
Last answer on 5/5/2016 2:14:48 PM. by Anany goel. Forum started by SatheeshB
1556
2125
Want to build 30*35 residential building suggest me some plans
Last answer on 1/5/2022 12:37:08 AM. by sweety. Forum started by ihsan
2558
Bye Law
2691
2924
2188
2184
2793
4520
1890
2284
2267
2767
3464
2356
1968
2242
3595
2324
2091
2792
1548
2114
Why
Proper
How To Repair Cracks
