Home -> Forums -> Construction -> Basement -> Retaining wall - Usage of Cement Plasticisers
Fri Jul 20, 2012Total posts : 1
George Kattapuram
George Kattapuram
Topic: Retaining wall - Usage of Cement Plasticisers
Dear All,
I am constructing a semi basement with aprox 6 feet deep basement floor level w.r.t ground level.
While preparing the retaining wall, I wnat to know what I shoudl do for waterproofing. ?
Someone suggested using cement plasticisers to mix in the cement concrete to reduce the amount of water added as this gives the same consistency and will reduce the honeycomb effect.
Is this correct.
are there other ways for waterproofing in the basement?
Someone also informed that the flooring in the basement must be with RCC so that grouting if required at a later stage can be done. ???
Pls advise.
George
Mon Jul 23, 2012Post  #1
Dear George
          you can use cement plasicisers according to the direction of manufactures.
For dampness treatment of walls and floors you should see the basement section in construction at gharexpert.com and see the link below
http://www.gharexpert.com/articles/Basement-1505/Water-Proofing-Treatment-Basement_0.aspx
3791
2191
What is the best colour for the inside walls if I want to retain the colour of t
Last answer on 10/26/2010 3:45:23 PM. by nevile. Forum started by Evas T. Bwoye
7005
3992
4209
Selection of cement ..
3074
1789
What are the special characters of different kind of bricks.Size of a cement bri
Last answer on 1/28/2014 2:44:37 PM. by S L Gupta (Civil Engg). Forum started by Dilip
2568
2404
2862
6470
1510
And how much is labour and material cost to chip old wall and replaster it with
Last answer on 11/8/2017 1:53:56 AM. by S L Gupta (Civil Engg). Forum started by Sheila
3928
1518
material Calculation
Last answer on 9/17/2015 12:18:10 PM. by S L Gupta (Civil Engg). Forum started by abhishek Kumar
1732
2657
1692
2022
How much White Cement will be required as Primer Coat on Fresh Raw Wall for appr
Last answer on 6/24/2013 3:01:38 PM. by S L Gupta (Civil Engg). Forum started by JAYANT VERMA
2420
9061
makan map
2774
17223
1993
2156
design of column
2281
2252
Underground water tank
2657
2764
foundation
2033
Full Plan Needed
3196
labour cost
3163
APP membrane
2796
1970
ffff
1872
4209
3465
2016
Regarding construction
3154
Basement Water proffing
2015
Acid staining
Canvas
Canvas Wall Art
Wall
Wall Decor
Paint
Wall
Wall Accents for Your Rooms
Post
Post Painting Works
