Home -> Forums -> Interior -> Bedroom Flooring -> Reusable flooring options
Tue Dec 01, 2009Total posts : 1
Kunal Mehta
Kunal Mehta
Topic: Reusable flooring options
Can  someone suggest me on flooring options which can be re-used and taken with me once i move out of the house.I know laminate wood flooring and carpet flooring can be reused but the places where i want to install them are likely to have some water problems ....and if i put tiles/marble etc, then they have to be broken to be removed so thats not a option.Any suggestions??....
Tue Dec 01, 2009Post  #1
anish
anish
Post subject: try Cork Flooring
Cork is the bark of the cork oak tree (Querus Suber) which grows in the western Mediterranean. The cork bark is formed from layers of extremely strong flexible cell walls that are waterproof and airtight. The cork tree produces this bark to provide protection from droughts, fires, temperature fluctuations and other damaging environmental conditions. This tree has a life span of 200 - 500 years. The first stripping takes place when the tree is 25 years old, thereafter, stripping is repeated every nine years. At no time during the life or the tree is more that 50% of the bark removed. Harvesting of cork is not harmful to the tree. During the cork manufacturing process, all material is either used for a finished product, or used to generate energy used in the fabricating process. Very little, if any material is wasted. This makes cork one of the mostenvironmentally sensitive products available.
This unique natural raw material with its lightweight, flexible honeycomb structure, is impermeable to liquids and gas, which makes it an ideal material for a myriad of household products. The properties of cork are derived naturally from the structure and chemical composition of the inner cells. Each cubic centimeter of cork contains between 30 and 40 million cells. It is this exceptional cellular structure that gives cork its essential characteristics.
INSULATION Because 90% of the tissue consists of gaseous matter, the density of cork is extremely low, giving the material wonderful insulating properties, thermal as well as acoustical.
RESILIENCE When cork is subjected to pressure, the gas is compressed and volume decreases considerable. Once released from pressure, cork recovers rapidly to its original shape.
DURABILITY Cork is remarkably resistant to wear, as it is less affected be impact and friction than other hard surface materials due to its cellular composition
IMPERMEABILITY The presence of Suberin, a natural waxy substance, makes cork is impervious to both liquids and gas. As a result it does not rot.
HYPOALLERGENIC Cork does not absorb dust and consequently does not cause allergies.
FIRE RETARDANT A natural fire retardant, cork does not spread flames, and does not release toxic gases during combustion.
Bedroom Flooring-Interior Questions (36)
1983
what are the different good wooden flooring options available...pl suggest
Last answer on 5/23/2011 10:12:30 PM. by S L Gupta (Civil Engg). Forum started by Reena
2003
can u suggest some flooring options for bedroom in the price range of 200-250 pe
Last answer on 7/18/2012 12:04:18 PM. by Ahsan Ali Junaid. Forum started by padmaraju
1399
Options for construction of staircase in east facing two duplex houses where the
Last answer on 9/15/2017 2:56:37 AM. by S L Gupta (Civil Engg). Forum started by Sandeep endla
419
Members, where are you looking for new skincare options?
Last answer on 11/8/2021 2:03:47 AM. by Cermit. Forum started by RadyGoldy
6381
kota Stone Roofing
5061
is neem wood good option for windows , Please suggest
Last answer on 5/24/2016 3:23:11 PM. by S L Gupta (Civil Engg). Forum started by boban
1776
7 year boy should study in which part of house.second best option also
Last answer on 9/12/2011 8:32:04 PM. Forum started by ricky singh
2219
Tips for Bed Room Lighting.
Last answer on 10/13/2012 11:48:53 AM. by S L Gupta (Civil Engg). Forum started by shivendra
1773
Mold & fungi at wall bottom sides
Last answer on 5/18/2013 1:55:52 PM. by S L Gupta (Civil Engg). Forum started by bharat
2824
If North east corner is cut then wt option is or wt we do for good
Last answer on 7/3/2020 9:36:24 PM. by JAI PRAKASH. Forum started by renu chandra
2274
Which Floor is better.. Top or Ground
Last answer on 6/15/2012 6:18:16 PM. by amit saini. Forum started by amit saini
2104
Vinyl Flooring
Last answer on 10/21/2010 8:22:02 PM. by priya. Forum started by Andrew Virgil
3455
for pooja room there is no any option for mandir except North west - then is it
Last answer on 3/7/2011 12:50:09 PM. by Nikita. Forum started by snehal
2615
house layout on 40*40 east facing site
Last answer on 9/9/2011 2:11:24 PM. by kawalnain kaur. Forum started by anilpande
2205
My house is under construction kindly advice the position of septic tank.Option
Last answer on 9/7/2010 5:46:10 PM. by sabina vanjani. Forum started by piyu sur
2310
New Pergolas Design For Your Home
Last answer on 5/28/2015 10:09:11 AM. by berashton. Forum started by berashton
1895
Wood for outdoor furniture
Last answer on 7/26/2015 4:39:53 AM. by Anuj Aggarwal. Forum started by Vishal
1866
false ceiling
Last answer on 4/19/2015 1:45:40 AM. by JAI PRAKASH. Forum started by avani_nagoree
2616
Exterior Walls
1951
I have a hall which should accommodate both drawing and dining. The room size is
Last answer on 2/7/2022 3:28:29 AM. Forum started by Pallavi
1473
Three Methods Of Wood Floor Maintenance
Last answer on 1/18/2022 11:11:29 AM. by S L Gupta (Civil Engg). Forum started by happywork
2248
Flooring for house
Last answer on 1/17/2022 11:13:36 AM. by S L Gupta (Civil Engg). Forum started by Archit Jain
2364
Good normal bathtub brand and material...
Last answer on 1/7/2022 2:10:41 AM. by raghuam. Forum started by raghuam
2216
Tiles or Marble for Flooring
2257
Latest trend in wooden flooring
Last answer on 7/4/2020 12:05:48 AM. by paramarsh. Forum started by jaai randive
Best tantrik in india Tantrik Baba ji +919878377317
Last answer on 2/15/2017 1:07:45 PM. Forum started by vvv22
1954
Last answer on 1/7/2017 3:42:26 PM. by Beenu Phogat. Forum started by BALDEV RAJ
1912
flooring
Last answer on 7/28/2016 3:08:23 PM. by Aarav Sharma. Forum started by sumit
1556
1890
Bathroom floor tiles
Last answer on 5/20/2014 8:43:39 PM. by JAI PRAKASH. Forum started by parag
2505
Terazzo flooring
Last answer on 2/9/2013 3:03:01 PM. by Blasio777. Forum started by Blasio777
2057
Bedroom Flooring
Last answer on 1/29/2012 11:18:07 AM. by greatwindowsss. Forum started by Suresh Kumar Regmii
2111
Cheap price floors
Last answer on 12/7/2011 2:40:01 PM. by ravi at Dalmia. Forum started by Huda
1733
Sir, Every things found alright. But we need more details for drawings and mate
Last answer on 11/29/2011 10:42:07 PM. Forum started by Habib
1917
Thanks for your recent feedback.I need some images and design for a kitchen.The
Last answer on 10/7/2011 11:34:29 AM. Forum started by Updesh Singh Bhangoo
1963
It was and its lovely
Last answer on 1/11/2011 7:25:39 PM. Forum started by monze
Types of Windows and Door options in uPVC
Cooper
Terrazzo
Refinishing Hardwood Floors
Checklists for flooring
Drawing
Drawing Room Flooring
Epoxy
Epoxy Flooring
Epoxy flooring can be defined as several layers of any type of epoxy resin that is applied on a floor surface. This ty..
