Home -> Forums -> Construction -> Raw Material -> Reusing material of old demolished house to construct a new house
Tue May 01, 2012Total posts : 1
pankaj sharma
pankaj sharma
Topic: Reusing material of old demolished house to construct a new house
Dear friends,
I am planning to construct a new house by demolishing my existing old house (42 yrs.old). Your valuable suggestion are required how to reuse good material of old house in construction of a new house. It will help for me a lot.
thanks
pankaj sharma
Tue May 01, 2012Post  #1
Dear Sharma
               At the time of dismenteling the old house, take care that all the usable items shold be removed safely.In general in the old house there are wooden batten, if they are in good condition than can be used for making frames of door and windows. The old bricks can be used after scraping and washing. The broken bricks can be used as brick bats for foundation and debris can be used for filling under floor to raise the floor level.
New Home
3080
we want to demolish this old house and want to construct a new one. but the problem is there are neighbors whose walls are in touch with our wall so if we demolish and if their wall collapse then we will have to construct their wall also.. they are not ready to construct a new one. what is the solution..
Last answer on 5/20/2014 2:47:38 PM. by S L Gupta (Civil Engg). Forum started by vijay
2603
Using old bricks for construction
Last answer on 11/3/2011 11:02:20 PM. by susandixon. Forum started by Col MP Singh
14267
Demolition of Old house and constructing New house
Last answer on 1/21/2011 11:04:22 AM. by Archit Jain. Forum started by Kanchana
2447
3436
sunmica
Last answer on 12/6/2012 10:52:25 PM. by shailesh kumar singh. Forum started by tanaji
14552
demolishing old house procedure & cost
Last answer on 11/15/2012 12:55:00 PM. by S L Gupta (Civil Engg). Forum started by latha
2647
2925
2017
RENOVATION
Last answer on 9/4/2010 5:47:46 PM. by S L Gupta (Civil Engg). Forum started by MANJUNATH
9893
3470
paint
10722
Life span of RBC lintel roof
1803
Hi All, I have a very old house (almost 70 years) in Kolkata on a 2 katha plo
Last answer on 7/1/2013 4:37:49 PM. by S L Gupta (Civil Engg). Forum started by sonali
2022
2962
5957
new construction in 300 sq yards place ...planning
Last answer on 2/20/2011 12:22:40 PM. by Gunjan Utraja. Forum started by vihal madishetty
1802
Want to construct a new house in limited budget, area 35*35 .
Last answer on 10/20/2015 2:24:22 AM. by JAI PRAKASH. Forum started by Kiran
2107
Last answer on 11/21/2015 12:12:42 PM. by SACHIN. Forum started by SACHIN
3076
RCC roof
1971
Marriage hall construction
2537
Function Hall
4201
11105
2189
2038
Estimate
11123
3073
Steel
3039
use of tmt bar
1643
work turned out by labour
2457
estimate
1762
2992
3606
1943
Cost of Steel construction
1613
2136
READY MIX PLASTER
1866
2223
zero slump concrete
Happy
Painting
Environmentally
Environment
Environment Friendly Houses
How to Paint Old Furniture
