Home -> Forums -> Construction -> Layout and House Plans -> Review my plan
Review my plan
Fri Mar 14, 2014Total posts : 1
satishb
satishb
Topic: Review my plan
Review my house plan
Postby bsat » 13 Mar 2014, 15:42
Hi All,
I am planning to build a house on a 30x50 plot. Please review the Floor plan and let me know the suggestions.
The description of the plan is below. The Facing of the plot is north-east (skew plot).
The floor plan attached has a) Ground Floor Plan b) First floor plan c) Second floor plan. First and second floor is duplex for our use, where as Ground floor will be stilt with car parking at present. In future want to plan to build ground for 2/1bhk 2 car parking and 2bhk at top floor. So the requirement for two stair case arises one for our use and the other for external usage. Any suggestion will be appreciated.
bsat
Attachments: ALL_FF.pdf on Fri Mar 14, 2014,&n
Tue Mar 18, 2014Post  #1
529
It is not easy to find reviews about brokers on the Internet. Most of the review
Last answer on 1/5/2022 4:27:17 AM. by HardissonHard. Forum started by Cermit
613
Last answer on 1/5/2022 12:33:34 AM. by Olivia James. Forum started by Cermit
634
Do you trust reviews on the internet?
Last answer on 2/22/2022 9:30:51 AM. by Rinder76. Forum started by Kirow44
1278
I would come back with review of map.
Last answer on 5/17/2016 1:35:10 PM. by S L Gupta (Civil Engg). Forum started by anil
1382
I need literature review on workshop/lab.
Last answer on 7/30/2011 1:12:39 PM. Forum started by onims
8307
east and north facing house plan please give reviews
Last answer on 2/3/2021 8:45:56 PM. by sulekha. Forum started by sulekha
2713
Review my House plan fro smaller floor area
Last answer on 7/4/2020 3:05:21 AM. by Purvi Panchal. Forum started by ANSHU
1594
1700
Vastu Review for my FLAT. Dear Vastu Experts,its a really good place to have qu
Last answer on 11/22/2013 1:02:31 PM. by S L Gupta (Civil Engg). Forum started by Aravind
4160
Last answer on 1/12/2021 1:49:30 AM. by Amritraj Dhaliwal. Forum started by Imran Khan
3555
Reviews on Wooden Flooring.
Last answer on 12/31/2020 2:02:23 AM. by H S Rathi. Forum started by Gomsi Arora
4374
RCC Columns
1844
Which elevator service company is the best for a residential place or semi commercial place?
Last answer on 1/5/2022 12:33:22 AM. by JAI PRAKASH. Forum started by Raghavendra Gudla
2821
Best house plan for 100 gaz (45feet x 20 feet)
Last answer on 6/9/2016 2:36:44 PM. by sanjay agarwal. Forum started by Ashish Tanwer
4902
2264
Please suggest me the best map plan for 8×18 meter plan accordingly to vastushas
Last answer on 4/2/2017 6:08:24 PM. by praveenshiraguppe. Forum started by Ganesh Kumar
1898
15654
9970
2697
2929
2194
2191
2804
4526
1896
2290
2277
2775
3469
2363
1976
2248
3600
2332
2096
2796
1554
2122
How to Plan Outdoor Lighting
Girl`s
Girl's nest
Girl’s room is a nest for daydreaming, studying, playing with dolls, sleeping and even doing a little makeup and spend..
