Home -> Forums -> Construction -> Basement -> Rework required on blinth beam.
Mon Sep 30, 2013Total posts : 2
ananth
ananth
Topic: Rework required on blinth beam.
Dear sir,
We are constucting a house with Grond(1400Sq Feet) , First (1600 Sq feet) floor and will extend the 2nd floor.
As per the structuarl drawing my builder has completed the blinth beam without included the all 11 column (total 16 column in the house)and only included front side 4 columns(help for support the steps and car parking area on top of the first floor) are extended to further support of the house.
This become a brick work construction without clolumn!
This is really bad. Now i am discontinued the builder and i am planning to rework on reamining 11 column in the blinth beam!
How can i do? Because column  steels are  inside the blinth beam and couldn't  join with and extend the remaining columns.
Please advice and it is really helpful.
Thanks,
Ananth
Mon Sep 30, 2013Post  #1
Post subject: Rework required on Plinth beam.
Dear Ananth, Hello....! Really its very difficult to say anything withut seeing your plan and structural details, its my sincere advise that you should contact Local qualified Structural Engineer and Architect for further work ...regards
Tue Oct 01, 2013Post  #2
DearAnanth
       You should follow the advice of Sh Navneet  that a Local qualified Structural Engineer/ civil engineer can solve this problem after inspecting the site.
    It is not clear from your question whether you laid footing for all the 16 columns or for only 4 columns.
3837
Roof Beam
3883
stone foundation
5691
2994
14599
1978
4430
2382
1897
COLUMN & BEAM WIDTH & HEIGHT REQUIRED
Last answer on 1/23/2016 8:27:23 PM. by JAI PRAKASH. Forum started by DURJOU KUMAR MONDAL
2259
STEEL BEAM & COLUMN
Last answer on 1/12/2016 12:30:46 AM. by JAI PRAKASH. Forum started by DURJOU KUMAR MONDAL
4664
Regarding Beam
4069
steel requirement
3129
Plinth beam at ground level
1311
2054
1940
3303
2331
beam load
Last answer on 9/16/2014 11:08:18 PM. by JAI PRAKASH. Forum started by rishabh
9061
makan map
2774
17223
1993
2157
design of column
2282
2252
Underground water tank
2657
2764
foundation
2033
Full Plan Needed
3196
labour cost
3163
APP membrane
2797
1970
ffff
1872
4211
Selection of cement ..
3465
2016
Regarding construction
3154
Basement Water proffing
2015
Acid staining
Centering
Dining
Dining Room Ceiling
