Robo Sand for Brickwork
Thu Feb 26, 2015
Naveen Reddy
Topic: Robo Sand for Brickwork
Hello Experts,
I wanted to check if we can use Robo sand for brick work as replacement for Sand. We are using AAC blocks for walls. There is a shortage of river sand in Hyderabad as Telangana govt imposed temporary ban on Sand mining. Please advise.
Thanks in advance,
Naveen
Fri Feb 27, 2015
Yes you can.
1763
vishal Thakur
1457
vishal Thakur
16073
robo sand vs natural sand
Last answer on 5/19/2014 11:46:14 AM. by
shaik khaja nayab rasool
3009
M-Sand for Plastering
Last answer on 10/14/2015 3:22:52 AM. by
Satheesh
13271
What is the advantage and disadvantage of using Robo Sand (stone crush) in RCC a
Last answer on 10/17/2014 9:27:21 AM. by
Ajith Prakash
3941
Last answer on 2/15/2013 11:15:40 AM. by
prassant kumar
prassant kumar
2012
coarse aggregate
Last answer on 8/10/2015 4:00:45 PM. by
satinder parshad
satinder parshad
3712
Last answer on 10/8/2014 8:42:33 PM. by
K S SHYAM SUNDER
2102
river sand
Last answer on 4/21/2014 3:55:50 PM. by
2745
Last answer on 8/14/2012 11:27:03 AM. by
George Kattapuram
2327
Sand units
Last answer on 1/6/2017 12:04:59 PM. by
Pasha
1706
Sand units
Last answer on 1/6/2017 12:04:34 PM. by
Pasha
1525
Sand units
Last answer on 1/6/2017 12:03:42 PM. by
Pasha
6450
Last answer on 10/8/2011 10:00:53 AM. by
Vinod
2242
sand alternate for concrete
Last answer on 10/9/2010 11:37:42 AM. by
G N Shaikh
manohar
3148
Last answer on 7/3/2020 9:54:13 PM. by
padmaraju
3791
Last answer on 9/21/2020 2:27:35 AM. by
krishna
1574
Hi plz sand me porch detail any tipe
Last answer on 7/4/2020 12:21:48 AM. by
vinod kumar
2306
is m sand adviceable toconstructwith bricks
Last answer on 1/23/2016 8:42:33 PM. by
ajitkumar
5811
Rakeeb Rathor
3792
Pandu
9884
nasad
2670
Sreedhar
4627
ani
4143
Anamika
2865
lio
ringwang
R.Roy
5006
MANISH
3655
Arvind Bhaskar
premkumarlen
1864
carmenjames
r.n.misra
2799
Sharath Kurva
Sharath Kurva
2609
gk
2372
Adriano Peres
vamsi
2462
nuksung
2638
dayal
1807
TUNDE
3607
ragha
6254
suba
Swimming Pool Filters
How To Repair Cracks
