Foundation
Tue Jan 05, 2016
satya
Topic: Rod size for Pillers and beams
I am planning to construct a g+2 house in 36X50 site.
I am attaching my ground floor central line drawing.
I want to know the rod sizes which we should use for the pillars and beams.
could you please help me in getting this information.
thanks in advance.
Satya.
pic848.pdf on Tue Jan 05, 2016,&n
Wed Jan 06, 2016
Dear Satya
The proper way of find out MS Steel bars number and diameter is to derive from structural drawing based on calculation of span of column load coming on beam and column, earth quack safety factor. So it is advised to take proper design.
Sun Jan 10, 2016
Use 16 mm for columns and 10-12 mm for Lantel and beams.
Foundation-Construction Questions (38)
8652
Last answer on 7/23/2012 11:37:26 AM. by
dominate27
2995
Last answer on 8/17/2015 1:16:00 PM. by
jaydeep
2824
Last answer on 8/22/2016 11:02:03 AM. by
Praveen
1945
Last answer on 7/3/2020 11:23:38 PM. by
rajesh
3884
stone foundation
Last answer on 10/13/2014 11:35:43 AM. by
itikalavhs
65239
Last answer on 7/3/2020 11:37:34 PM. by
syed
Jitendra Sindhi
3838
Roof Beam
R.Roy
3134
Last answer on 12/17/2020 11:30:34 PM. by
deepu
1979
Last answer on 7/3/2020 11:53:47 PM. by
AD
1786
foundatio
Last answer on 10/6/2014 1:25:17 PM. by
nitu
3180
Last answer on 3/14/2021 11:13:22 AM. by
venkatesan.pt.
1903
roofing
Last answer on 10/14/2015 3:25:36 AM. by
sumit
4431
Last answer on 1/7/2017 7:22:09 PM. by
roshan
roshan
3272
Roof Concrete Strength
Last answer on 10/12/2014 8:43:10 PM. by
Jahankumar
ringwang
R.Roy
2687
Steel Size
Last answer on 8/21/2014 12:31:17 PM. by
ferous
1973
I have built a house in 1600 sqft in ground floor with out piller beam. now I wa
Last answer on 12/21/2011 10:42:01 AM. by
ravi at Dalmia
siba charan sahoo
1762
mohd asif
1743
beam rod details
Last answer on 7/27/2016 1:14:29 PM. by
brigith jose dopson
2684
Pillar
Last answer on 2/24/2022 11:04:22 AM. by
keshavthakur
2140
Curing urgent
Last answer on 2/23/2022 5:17:08 PM. by
Rohit Sharma
Pooja
2372
structure work
mamtagarg
manish agarwal
5166
Pillar foundation
Last answer on 2/1/2022 10:02:34 AM. by
joe kurian
joe kurian
2204
new house
Last answer on 1/5/2022 2:13:15 AM. by
Janette
ananth
2821
building a house
nashir
1992
Construction Agreement
Last answer on 12/21/2021 12:56:56 AM. by
Abhijit
3091
Foundation
kamal
2272
Foundation
Last answer on 12/20/2021 6:20:53 AM. by
Gagandeep
1476
Last answer on 11/13/2021 8:11:49 AM. Forum started by
passwordc
10048
manishkumar
manishkumar
3660
Foundation
Rohit Sharma
2115
Structure proof checking
Arnab Ghosh
2558
Foundation design
DavidFlores18
nithun
2462
Last answer on 5/22/2021 11:37:00 PM. by
mayowa
2468
Saria and cement
Last answer on 3/25/2021 4:28:11 AM. by
ARVIND GOYAL
3657
Wall Thickness
Last answer on 12/31/2020 2:31:58 AM. by
shankar
2679
Last answer on 7/28/2020 12:37:29 AM. by
K M Sendhil
13267
Steel Type
Last answer on 7/4/2020 2:48:38 AM. by
erbharathi
sumit dua
Right size cupola
Dining Room Ceiling
What is binding wire
