Home -> Forums -> Construction -> Cement Paint -> Roof Painting
Roof Painting
Tue Mar 17, 2015Total posts : 2
Swarup Kumar Dey Choudhury
Topic: Roof Painting
I am building my house 1100 sq ft. I have a budget of 7 LC. The Slab work is complete. The slab is ^ Shaped. Want to give a tile design look. Instead of putting roof tiles I have drawn the tile design in it to reduce cost.
Now want to give the colours in it. .....
Does any one have any idea how colours are given in concrete.
Shall I mix Red OXide in concrete mixture ? I know colours are mixed in concrete. Seen in Paver Blocks in roads and lawns. Will the concrete be strong enough ? Shall I paint red oxide after plastering , when it is not dry and hard ?
Any good Indian website for information about name of colour, brand, procedure to mix etc.
I would be grateful again for valuable feedback ..
Attachments: images (3).jpg on Tue Mar 17, 2015,&n
Thu Mar 26, 2015Post  #1
Post subject: Roof painting
         If you will mixed red oxide in concrete it will be decrease strength of concrete.. 2nd option is better than 1st ..so you can paint red oxide after plastering .
Sat Mar 28, 2015Post  #2
Please paint red oxide after plastering.
Cement Paint-Construction Questions (20)
2265
id like to know...is this paint or is this whole effect on the roof,given by a f
Last answer on 5/5/2011 5:50:43 PM. by P. Panchal. Forum started by amina
2971
Tips for Cement Paint
3170
4568
PAINTING
Last answer on 2/24/2022 12:54:30 PM. by Girish. Forum started by Girish
4510
Wall Putty ,primer and paint
2219
waterproofing concrete flat roof
Last answer on 5/27/2015 1:58:25 PM. by helgajones. Forum started by arindam kar
8426
Roof Beam crack
4047
Paint vs Wallpaper
2549
need paint in my house so wants to see a demo of drawing room how it look after
Last answer on 7/3/2020 10:09:31 PM. Forum started by muddassir
2219
Do you have paint reps in the USAaround the northwest Indiana area.I have a cust
Last answer on 11/16/2012 8:35:46 PM. Forum started by Jackie Martin
1803
Last answer on 8/29/2016 12:10:36 PM. by S L Gupta (Civil Engg). Forum started by vishal
3083
3078
Painting
1649
2061
4655
2341
2857
2377
Roof construction
1718
cement pain for exterior
Last answer on 12/5/2012 3:48:43 PM. by S L Gupta (Civil Engg). Forum started by aammiitt
Cooper
Aluminum
Aluminum Roof
Asphalt
Asphalt Shingles Roofing
Wood
Wood Roof Shingles
