Home -> Forums -> Construction -> Start Construction -> Roof TMT needs
Roof TMT needs
Mon Dec 28, 2015Total posts : 5
Rohit Sharma
Rohit Sharma
Topic: Roof TMT needs
I would be building G+1 or ( maximum to maximum G+1+ 1/2).
Considering 10mm sttel bars and 8mm for distribution in roof slab(lanter). Is it okay?
Secondly, I have tight budget. so i have not laid plinth beam and but my mistri put two 12mm rods at DPC level.( In punjab we call this type of arrangement as tega). and I want to put only 1 beam per acrross the building per floor. So should i put beam at roof level and two rods of 12mm at lintel level where there are door openings OR put full beam at lintle level and no beam at roof level?
Help!!!
Mon Dec 28, 2015Post  #1
Dear Rohit Sharma
      Have proper design if not  Lay lintel on door and window opening, lay beam if required ' 10 and 8 mm steel is OK
Tue Dec 29, 2015Post  #2
Rohit Sharma
Rohit Sharma
Thank you sir,
I have attached my plan G+1 here. I will lay lintel at doors and windows. So after that if I want to add beam then where it should be put? Lintel or roof? I mean where it is important?  Please look at full house plan
Attachments: ground floor working.rotated.pdf Tue Dec 29, 2015,
First floor.jpg Tue Dec 29, 2015,&n
Tue Dec 29, 2015Post  #3
Rohit Sharma
Rohit Sharma
Also, tell me if beam is really required as per given plan?
Tue Dec 29, 2015Post  #4
Use 16 mm in column's. 10-12 mm in lantel. You need the beam as required.
Tue Dec 29, 2015Post  #5
Dear Sharma
        Lintel beam on door and window is ok and lay beam at roof level.
3753
1740
2221
For 1850 sq.ft flat roof ,what mm tmt bars used my hall size 21*21 and 11*17 and
Last answer on 8/1/2018 11:18:57 PM. by S L Gupta (Civil Engg). Forum started by satheesh
2249
sir, what are the precautions need, to make a swimming pool on the roof.
Last answer on 10/6/2021 6:10:46 AM. by S L Gupta (Civil Engg). Forum started by Gagan Matharoo
2289
I need details on Metal Roofing
Last answer on 6/4/2021 9:27:52 AM. by leelindsey. Forum started by SAJATALI
2613
1622
1589
1503
24767
2493
Used M15 (1:2:4) mix ratio with PPC cement for casting ground floor house roof slab
Last answer on 2/21/2017 12:28:02 PM. by S L Gupta (Civil Engg). Forum started by vinu
2850
1st floor partition wall through the center of 14ft x 13 ft room rcc roof
Last answer on 11/1/2015 6:50:49 PM. by JAI PRAKASH. Forum started by vinu
1695
Roof related
Last answer on 3/5/2016 10:32:12 PM. by JAI PRAKASH. Forum started by Pooja
1530
1992
Residential complex
4651
3795
1544
Sir I have a plot of length 55.9' and width 17.4' south fasing entrance and 28'
Last answer on 4/18/2015 9:37:30 PM. by JAI PRAKASH. Forum started by Rakesh Singh
3039
use of tmt bar
3312
2236
2312
2061
Cooper
TMT
Asphalt
Asphalt Shingles Roofing
Wood
Wood Roof Shingles
