Roof Weathering
Tue Jun 07, 2016Total posts : 4
Mohan
Mohan
Topic: Roof Weathering
After RCC completion Weathering with Cement is Good or Purt mosaic tile fixing is Good.Which one is better leak Proof?
otherwise any other methods are there for weathering. Please advise.
after some years we are plan to construct first floor but not sure for that case which one is best?
Wed Jun 08, 2016Post  #1
Dear Mohan
        Clay tiles/ brick tiles is the best option for roof terracing. Do proper bitumen coat on roof surface and lay bitumen coated sheet and lay earth at required slope and lay tiles and grouting with cement mortar, cure it. If you want flooring after some years than remove tiles and earth and lay brick ballast on roof and lay required floor.
Wed Jun 08, 2016Post  #2
Mohan
Mohan
Thanks For your Advise...
Tue Jul 12, 2016Post  #3
Aarav Sharma
Aarav Sharma
Hi Mohan! Based on my professional experience I would advise using a waterproof cement mixture rather than tiles. In my experience, while both may be effective in the initial stages, tiles will be more susceptible to leakage in the long run. What works best I find is to use a polymer-modified cement based waterproof coating on the roof. Since it is an acrylic reinforced compound it keeps the water out and also lasts for a long period of time. I usually use Roff Hyguard as I like the quality as well as how easy it is to use.
Wed Jul 13, 2016Post  #4
Dear Sharma
1791
weather it suitable for east facing plot.
Last answer on 1/19/2015 1:34:29 PM. by VastuMoorthy. Forum started by L.C.Sharma
15495
apex ultima vs weather coat? please help me choosing the right exterior paint. a
Last answer on 12/6/2012 11:46:26 AM. by S L Gupta (Civil Engg). Forum started by rajarshi ray
1757
2771
1673
2321
Dear sir by looking our house map could u pls tell us weather our house as per v
Last answer on 3/26/2013 6:39:15 PM. by Pavan. Forum started by Ramesh
6310
terrace flooring
Last answer on 7/3/2020 10:25:00 PM. by JAI PRAKASH. Forum started by Radhika
5003
Weathering course
Last answer on 7/25/2014 9:42:13 PM. by JAI PRAKASH. Forum started by Radhika
8426
Roof Beam crack
2857
3985
Roof leakage
2377
Roof construction
1649
2161
1842
1800
2061
4655
AuStRalia!!CaNaDa" 91- 8769373431VASHIKARAN sPeCiAlIsT
Last answer on 12/30/2024 1:08:23 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:08:17 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:08:11 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:08:05 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:58 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:52 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:46 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:40 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:34 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:07:27 AM. Forum started by rupeshji
Muslim-Shakti-Astro 91-8769373431Black Magic Specialist In Dubai,,qatar
Last answer on 12/30/2024 1:06:59 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:47 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:39 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:33 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:27 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:21 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:15 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:09 AM. Forum started by rupeshji
Last answer on 12/30/2024 1:06:03 AM. Forum started by rupeshji
Boy / Girl 91-8769373431~iNtErCaSt LoVe MaRrIaGe;;LoVe BaCk SpEcIaLiSt
Last answer on 12/30/2024 1:05:50 AM. Forum started by rupeshji
Cooper
Cupola accessories
Detailed information about cupola accessories
Aluminum
Aluminum Roof
Wood
Wood Roof Shingles
