Home -> Forums -> Construction -> Raw Material -> Roof construction
Roof construction
Wed Sep 04, 2013Total posts : 1
aliceria
aliceria
Topic: Roof construction
Does a metal roof cost more than a typical roof?
Give your idea for my new flat..
Thu Sep 05, 2013Post  #1
   Your query is not clear, write in detail so that answer can be given.
2378
Roof construction
5252
1676
roof vibrates while jumping
Last answer on 12/17/2016 1:58:23 PM. by S L Gupta (Civil Engg). Forum started by sandeep patel
8429
Roof Beam crack
4954
4655
2342
2038
12272
2513
Tile roofing
Last answer on 1/13/2014 2:42:23 PM. by S L Gupta (Civil Engg). Forum started by sourabh
2271
RCC roof on other than pillar
Last answer on 11/26/2015 3:34:20 PM. by S L Gupta (Civil Engg). Forum started by Binoy Rabha
3172
APP membrane
1981
Contractor charge details
Last answer on 3/28/2014 12:09:26 PM. by S L Gupta (Civil Engg). Forum started by sandeep dutta
2999
1818
Roof Lekage and Construction of New House
Last answer on 5/1/2015 12:48:12 AM. by JAI PRAKASH. Forum started by VIJAY
2658
Cost of construction of roof slab.
Last answer on 9/13/2013 11:42:05 AM. by feroz khan patthan. Forum started by suhas
3091
Construction of shed of steel structure with CGI roofing
Last answer on 1/29/2019 12:31:10 AM. by S L Gupta (Civil Engg). Forum started by S K MOHINDRA
191929
1210
construction on roof
Last answer on 8/17/2016 12:10:59 PM. by S L Gupta (Civil Engg). Forum started by bibhas naik
3082
RCC roof
1976
Marriage hall construction
2542
Function Hall
4213
11124
2199
2042
Estimate
11134
3077
Steel
3041
use of tmt bar
1650
work turned out by labour
2465
estimate
1768
3017
3610
1945
Cost of Steel construction
1619
2141
READY MIX PLASTER
1867
2230
zero slump concrete
Iron
Iron Sheet Roofing
Cooper
