Home -> Forums -> Construction -> Cement Concrete Flooring -> Roof flooring
Roof flooring
Thu Sep 04, 2014Total posts : 3
ravi pachipala
ravi pachipala
Topic: Roof flooring
How do we do the flooring on the terrace ? Masioner is suggesting to do the flooring using sand and cement as the floor thickness is coming around 1.5 inch. He is suggesting to use coarse aggregate only if the thickness is more than 2 inch. Please provide expert advise.
Fri Sep 05, 2014Post  #1
Dear Ravi
         on the terrace use brick tile flooring as cement concrete flooring will be crack after some time. If you want stone flooring than use chips flooring strip pus between 2 stone.
Fri Sep 05, 2014Post  #2
ravi pachipala
ravi pachipala
Dear sir .. thanks so much for the response. I am planning for tiles flooring on terrace. could you kindly guide me with more details on usage of chips. Sorry for tasking these basic details. ravi
Sat Sep 06, 2014Post  #3
Dear Ravi
        See the link below for terrazo/ chips flooring
http://www.gharexpert.com/articles/Flooring-1495/Terrazzo-flooring-Mosaic-or-Marble-chip-flooring-_0.aspx
Cement Concrete Flooring-Construction Questions (27)
29941
3266
estimate for rcc slab
Last answer on 7/4/2020 2:02:41 AM. by S L Gupta (Civil Engg). Forum started by vinod
12307
What are the advantages of Kota stone flooring?
Last answer on 6/27/2010 4:58:24 PM. by Ramen Roy. Forum started by harsh
1801
help me to give a structure for my home
Last answer on 10/20/2014 11:38:13 AM. by S L Gupta (Civil Engg). Forum started by sajna
2211
Roofing cost for 3000 sqft 2nd floor roof
Last answer on 6/17/2015 6:56:38 AM. by JAI PRAKASH. Forum started by sira
12251
4365
WHAT IS THE RATIO
25607
CURING TIME FOR RCC ROOF
1518
i WOULD LIKE TO COVER 2ND floor BALCONY WITH ROOF AND CEILING.IS THERE ANY BODY
Last answer on 7/9/2016 2:06:00 PM. by S L Gupta (Civil Engg). Forum started by ramachandra
3347
2352
laying of roof
8420
Roof Beam crack
2849
1st floor partition wall through the center of 14ft x 13 ft room rcc roof
Last answer on 11/1/2015 6:50:49 PM. by JAI PRAKASH. Forum started by vinu
10722
Life span of RBC lintel roof
42597
Labour Cost for Roof RCC work
2912
RCC ROOF LEAKAGE
Last answer on 12/5/2012 1:40:32 PM. by S L Gupta (Civil Engg). Forum started by sivarajen
1268
Getting sunlight inside ground floor of two story home
Last answer on 11/21/2016 1:34:46 PM. by S L Gupta (Civil Engg). Forum started by vinu
2054
1393
3589
Per Sq:ft rate for flooring
1398
Colored concrete floor
Last answer on 10/22/2016 11:14:47 AM. by S L Gupta (Civil Engg). Forum started by Pooja
1521
concrete floors
1989
1641
floor construction
2122
Floor thickness
2465
Material and cost of Tezzarro flooring
Last answer on 7/20/2012 11:33:53 AM. by S L Gupta (Civil Engg). Forum started by Raj
Cooper
Aluminum
Aluminum Roof
Asphalt
Asphalt Shingles Roofing
Wood
Wood Roof Shingles
