Home -> Forums -> Interior -> Home Improvement -> Roof insulation
Roof insulation
Fri Sep 19, 2014Total posts : 1
sb
sb
Topic: Roof insulation
My flat is on the first floor with open terrace above. What is the best way to insulate roof to prevent heat radiation? I am thinking of erecting roof top shed - is this a good idea? If yes, what is the best material for the shed? Steel sheet? Asbestos? or FRP sheets? Please suggest. Thanks.
Sat Sep 20, 2014Post  #1
hermal insulation is a method to reduce the transfer of heat from outside to inside. To make house heat proof, thermal insulation is a good choice. An insulated home is more comfortable as the temperature remains consistent over weather changes. It makes the house comfortable and keeps the temperature of   house cool in summers and warm in winters. It is very useful to keep the temperature of the house independent from outside temperature.See the link below
http://www.gharexpert.com/articles/Finishing-1607/Thermal-Insulation-Home_0.aspx
2829
1679
Concrete Roof Insulation
Last answer on 6/25/2016 11:19:30 AM. by S L Gupta (Civil Engg). Forum started by Omar Chaudhry
INSULATIONS
Last answer on 11/16/2009 6:59:34 PM. by Girish. Forum started by Girish
1808
Can someone tell me roof insulation details. or if someone can guide me for the
Last answer on 8/8/2017 2:02:31 AM. by S L Gupta (Civil Engg). Forum started by Aqua
8419
Roof Beam crack
1548
Insulating roof using used cement bags
Last answer on 3/26/2015 1:35:41 AM. by JAI PRAKASH. Forum started by Arvind Bhaskar
2569
Thermal Insulation of Home
Last answer on 3/29/2010 7:23:40 AM. by abhijeet pawar. Forum started by akkulshrestha
2047
Insulation and energy efficient houses
Last answer on 9/28/2011 5:25:10 AM. by Mohammad Baqar. Forum started by Mohammad Baqar
3979
Roof leakage
2849
2370
Roof construction
2158
1837
1791
1647
4647
2053
12251
2355
Refinish a Vinyl Floor
2521
Introduction
1087
Home appliances
2369
2964
layout plan
2181
Window Curtains For Home
3426
Reg: Interior design software
4764
2718
Living Room Decoration Ideas
2238
2033
2212
floor tiles
797
Online dating
2543
4041
Paint vs Wallpaper
2528
Design for a pooja room
9539
Wall Putty and primer
Straight Drop Awnings
2753
Kids Room Theme
2019
sapty tank
Thermal
No one likes to work in an uncomfortable environment where the temperature is either too hot or too cold. It is import..
Cooper
Aluminum
Aluminum Roof
Asphalt
Asphalt Shingles Roofing
