Home -> Forums -> Construction -> Brick Walls, Pillars and Structure -> Roof Beam
Roof Beam
Wed Oct 15, 2014Total posts : 1
R.R
R.R
Topic: Roof Beam
What size of RCC beam and roof thickness required for span size 17 feet length by 17 feet width without any supporting beams.
Thu Oct 16, 2014Post  #1
12"
5"
2054
4665
Regarding Beam
8421
Roof Beam crack
3272
Roof Concrete Strength
5486
Roof Slap & Roof Beam
Last answer on 7/4/2020 2:23:44 AM. by S L Gupta (Civil Engg). Forum started by Jahankumar
1979
2738
Regarding roof beam
3575
4162
I want to know what size/depth is required of roof beam & thickness of RCC Roof slab ir, I want to know what size/depth is required of roof beam & thickness of RCC Roof slab for my 17'-3" length & 16'-9" width dining hall. I am attached the
Last answer on 10/17/2014 12:01:24 PM. by S L Gupta (Civil Engg). Forum started by R.Roy
12252
3900
For G 2 residential building, column size 9"*15",16mm 4rod,12mm 2rod used.. hori
Last answer on 7/4/2020 2:29:23 AM. by S L Gupta (Civil Engg). Forum started by Sathya
7292
17'-6" length & 17'-0" width dining hall.
Last answer on 10/17/2014 11:53:30 AM. by S L Gupta (Civil Engg). Forum started by R.Roy
3151
Steel in Lintel
Last answer on 7/4/2020 3:06:52 AM. by JAI PRAKASH. Forum started by krishna pratap
5692
9196
2519
3303
2995
5811
3793
9885
2670
4628
4143
2865
5008
3657
1865
2801
2610
2373
2462
2638
1807
3608
6254
Cooper
Centering
Aluminum
Aluminum Roof
Asphalt
Asphalt Shingles Roofing
