Home -> Forums -> Construction -> Start Construction -> Roofing cost for 3000 sqft 2nd floor roof
Sat Jun 13, 2015Total posts : 3
sira
sira
Topic: Roofing cost for 3000 sqft 2nd floor roof
What is the total cost for concrete Roofing cost for 3000 sqft 2nd floor roof of ideal dimensions(including RCC, MSSteel, Cement, Concrete & LABOUR etc.)
Thanks for your quick response.
Tue Jun 16, 2015Post  #1
5-6 lac's. Depend upon how many beams to be used.
Tue Jun 16, 2015Post  #2
sira
sira
It'll contain 8 beams of 12ft length each
Wed Jun 17, 2015Post  #3
It will be around 5-6 lac's only.
1647
2649
1520
i WOULD LIKE TO COVER 2ND floor BALCONY WITH ROOF AND CEILING.IS THERE ANY BODY
Last answer on 7/9/2016 2:06:00 PM. by S L Gupta (Civil Engg). Forum started by ramachandra
25608
CURING TIME FOR RCC ROOF
1381
what would be total expense to install rubber sheet on roof of 780 sqft
Last answer on 9/24/2016 12:49:20 PM. by S L Gupta (Civil Engg). Forum started by DHIRENDRA
3002
House Estimation Breakdown
4647
2914
construction suggestion needed
Last answer on 12/21/2011 9:40:34 AM. by ravi at Dalmia. Forum started by rajan
12307
What are the advantages of Kota stone flooring?
Last answer on 6/27/2010 4:58:24 PM. by Ramen Roy. Forum started by harsh
11568
Brick wall and Lintel construction cost per SqFt
Last answer on 6/7/2015 1:27:14 AM. by JAI PRAKASH. Forum started by DD Gandhi
8421
Roof Beam crack
12252
1448
Roofing Cost of HINDALCO STEEL SHEETS
Last answer on 5/3/2016 11:35:20 PM. by JAI PRAKASH. Forum started by sira
42599
Labour Cost for Roof RCC work
18435
3608
2510
Tile roofing
Last answer on 1/13/2014 2:42:23 PM. by S L Gupta (Civil Engg). Forum started by sourabh
3312
2312
2061
Cooper
Aluminum
Aluminum Roof
Asphalt
Asphalt Shingles Roofing
Wood
Wood Roof Shingles
