Room wall not on Beam
Wed Mar 11, 2015
vijay
Topic: Room wall not on Beam
Hi Sir,
Normally, the room walls inside the house will rest on the beams of the slab. ( especially if the walls weight is not reaching till the ground.) .
I have a scenario, where i am planning to leave the ground floor completely empty for parking. In the first floor, some of the room walls are not exactly sitting on the beams. Will the slab be able to with stand the weight of the room walls if they dont sit on the beam.
vijay G
Wed Mar 11, 2015
Yes you can do that. But before doing this you have to take advise from architect or engineer. Building structure should be designed properly. Otherwise it can be risky for you..
5862
Last answer on 11/13/2016 12:55:24 AM. by
srikanth
3575
Last answer on 7/3/2020 10:21:24 PM. by
AD
3304
Last answer on 7/3/2020 10:11:02 PM. by
manjula
4665
Regarding Beam
Last answer on 7/3/2020 10:42:19 PM. by
Manikandan
1366
Last answer on 7/28/2020 12:37:49 AM. by
vishal singh
4799
tie beam obsolete
Last answer on 7/3/2020 11:09:31 PM. by
AD
2054
Last answer on 2/15/2017 1:14:19 PM. by
Rajkumar
3129
Plinth beam at ground level
Last answer on 6/11/2016 12:17:38 PM. by
santhosh
2332
beam load
Last answer on 9/16/2014 11:08:18 PM. by
rishabh
858
Last answer on 7/29/2020 4:17:12 AM. Forum started by
Rahul T Pal
2185
Bending the pillar rods on first floor
Last answer on 10/13/2016 11:16:31 AM. by
Saneto Fernandes
9196
Vinod
2675
Last answer on 1/10/2022 11:40:17 PM. by
vaishali
1280
if the room top not toching the roof then it is considered as room
Last answer on 10/30/2017 11:59:46 PM. by
div
1206
construction on roof
Last answer on 8/17/2016 12:10:59 PM. by
bibhas naik
19155
Last answer on 7/3/2020 10:47:35 PM. by
Techman
2504
Length of cantilever beam
Last answer on 7/3/2020 11:33:29 PM. by
ABCD
2738
Regarding roof beam
Amit Kumar
3200
Ready Mix Concrete
Last answer on 10/7/2013 11:24:46 AM. by
sck
Canvas Wall Art
Wall Accents for Your Rooms
Wall Decor
