Home -> Forums -> Construction -> Raw Material -> Rough construction estimation
Thu Nov 11, 2010Total posts : 2
llshyam
llshyam
Topic: Rough construction estimation
I own a house in Warangal, A.P. The ground floor is already built, and the first floor and second floor are having concrete slabs and the total construction area will be around 3000 sq.ft.
I would like to know what could be the rough cost for the constrction.
Here are the details:
Ist floor slab area - 2000 sq.ft (including veranda, and steps)
IInd flloor slab area- 1000 sq.ft (including veranda, and steps)
- The concrete slabs are already done, stair cases are done.
- I will be planning for 2- 2BHK in first floor, and 1 - 2BHK in second floor.
- I can go with medium quality fittings for sanitary
- I will go for medium quality electrical/paintings
- Door frames will be taekwood, shutters are plywood.
- Vitrified tiles
Shyam
Fri Nov 12, 2010Post  #1
Dear Shyam
                For estimate the plan of proposed house is required to calculate the quantity of work done from where one can be able to calculate the cost of the proposed house. you should send your proposed house plan with details at the support@gharexpert.com for estimating.
Fri Nov 12, 2010Post  #2
Post subject: Free service for rough cost estimate
GharExpert provide free service of rough cost estimate. Use the link given below:
But if you like to have brick by brick estimate then you can have detailed cost estimate service.
Click on the link to view the sample
Please send the details for detailed cost estimate at support@GharExpert.com
1784
2799
does any body have construction cost estimation free software?
Last answer on 7/13/2012 4:04:59 PM. Forum started by rajeev
5856
Estimation for ground + 2 floor
Last answer on 2/27/2015 10:52:31 PM. Forum started by sboloor
1646
discussion about home
Last answer on 7/16/2015 10:26:56 PM. by JAI PRAKASH. Forum started by rohit maurya
2440
2788
2504
estimation
Last answer on 4/20/2021 6:23:24 AM. by assainar. Forum started by assainar
2303
how to calculate brick estimation
Last answer on 1/22/2022 7:01:42 AM. by bhuvaneshwaran bn. Forum started by mohammed nayeemuddin
2421
3179
Estimation software
Last answer on 10/10/2021 12:12:30 PM. by Lola Cooper. Forum started by chethan
2827
ESTIMATION
Last answer on 10/17/2012 4:20:51 PM. Forum started by AHAMED YUSUFF
8160
software
2876
estimation
2971
i need structural details and estimation for 150yd plot
Last answer on 8/17/2012 11:36:21 AM. by Gunjan Utraja. Forum started by gangula
4797
Last answer on 1/13/2014 2:23:28 PM. by S L Gupta (Civil Engg). Forum started by balaji
4722
Cost estimation for sump tank
plan according to vastu for for my house construction
Last answer on 12/30/2014 11:54:37 AM. by krishna. Forum started by krishna
4136
House Construction estimation in 20 * 30 plot
Last answer on 1/4/2022 8:49:40 PM. by JAI PRAKASH. Forum started by Jyothirani Venkatrao
3075
RCC roof
1971
Marriage hall construction
2537
Function Hall
4201
11102
2189
2037
Estimate
11122
3072
Steel
3039
use of tmt bar
1642
work turned out by labour
2457
estimate
1762
2991
3606
1943
Cost of Steel construction
1612
2135
READY MIX PLASTER
1864
2223
zero slump concrete
Arcade (Architecture)
what is an arcade? Read the article to know more about it.
Brick Arches
