Home -> Forums -> Construction -> Start Construction -> Rough estimate
Rough estimate
Wed Apr 22, 2015Total posts : 2
JOY SINHA
JOY SINHA
Topic: Rough estimate
I have a house in Salt Lake, Kolkata. It was built in 1980s. It has 1 floor now.
I wish to add a second floor of 1400 sq ft. I will retire there in 5 years.
I would want better than average flooring/ cabinets/ wood-work/ kitchen/ bathroom.
How much money should I be thinking of? How many months should this take if I want to start after the rains? Are there a set of architects in Salt Lake, Kolkata that you recommend? Architects who will build this?
Fri Apr 24, 2015Post  #1
     Cost of building is depend upon the plan of building and specification adopted during construction, elevation and height of building, Type of floor, thickness of slab, size of column etc. These all things have effect on the rate per sft.If I say any rate on the hit and trial method that serves no purpose. If You have  estimate than you will be in better position to deal the contractor. In my view if you spent a small amount on proper planing, estimate etc which will benefit you more.If you want the service of gharexpert than see the link below or contact at suppot@gharexpert.com.
Sat Apr 25, 2015Post  #2
Hi Joy,
Your house was built in 1980's. There are very less chances to change the internal planning (layout) of your house. To change it you may need to add columns from the ground floor which may cost you to change the entire floor of ground floor.
You can add a second floor of 1400 sq ft but the construction must be wall on walls or add columns.
For better than average flooring/ cabinets/ wood-work/ kitchen/ bathroom you may need around 24 lac's for new floor and 10-12 lac's for ground floor renovation.
It will take around 10-11 months.
6228
4130
House Construction estimation in 20 * 30 plot
Last answer on 1/4/2022 8:49:40 PM. by JAI PRAKASH. Forum started by Jyothirani Venkatrao
1870
Estimate for 3rd and 4th floor
Last answer on 11/17/2016 10:32:27 AM. Forum started by Shubhank Gaur
2140
ESTIMATED COST FOR NEW BUILDING CONSTRUCTION IN RURAL AREA.
Last answer on 10/15/2015 2:19:56 AM. by JAI PRAKASH. Forum started by chitta naik
2326
I WANT TO KNOW THE ROUGH ESTIMATED COST FOR NEW 1450 SQ.FT. BUILDING CONSTRUCTI
Last answer on 10/15/2015 2:18:10 AM. by JAI PRAKASH. Forum started by chitta naik
1874
RCC roof cost
Last answer on 7/2/2013 7:58:54 PM. by Arjun. Forum started by Arjun
10561
cost of industrial shed
Last answer on 7/23/2013 11:20:11 AM. by S L Gupta (Civil Engg). Forum started by aakesh
1160
RECONSTRUCTION
Last answer on 8/6/2013 2:54:04 PM. Forum started by VISHNU
3585
Cost for a Residential Elevator
Last answer on 10/31/2010 7:55:25 AM. by Sundeep. Forum started by Sundeep
4963
Cost estimate for raising compound wall and shops
Last answer on 1/6/2012 2:32:27 AM. by ravi at Dalmia. Forum started by mrakesh
1803
My suggestion to the Ghar Expert. Rates per unit filled in Estimator (default v
Last answer on 10/23/2012 9:24:22 PM. Forum started by pankaj sharma
3337
Sample layout for building flats on my plot, and rough cost estimate
Last answer on 10/21/2012 11:03:49 PM. Forum started by solemnamritanshu
3640
5099
i need a rough floor plan for my south facing plot 40 x70=2800 sqft ;Gf- complet
Last answer on 8/23/2013 12:08:10 PM. by S L Gupta (Civil Engg). Forum started by H R SATISH
2441
rough plan
Last answer on 6/28/2013 1:28:25 PM. by S L Gupta (Civil Engg). Forum started by PSreddy
a plot of 15×60 two room set + drwing+ lobby
Last answer on 5/10/2016 7:25:53 PM. Forum started by Sanjay arora
Last answer on 5/10/2016 7:25:56 PM. Forum started by Sanjay arora
Last answer on 5/10/2016 7:25:58 PM. Forum started by Sanjay arora
Last answer on 5/10/2016 7:25:59 PM. Forum started by Sanjay arora
2451
3273
3284
4429
3975
2197
2699
4210
5167
2378
2294
1996
2447
2114
3194
2046
12514
2164
2010
2726
Arcade (Architecture)
what is an arcade? Read the article to know more about it.
Brick Arches
