Home -> Forums -> Construction -> Pillar Work -> WHAT SHOULD BE THE STANDARD DISTANCE BETWEEN TO PILLARS
Tue Dec 01, 2009Total posts : 3
SARDAR
SARDAR
Topic: WHAT SHOULD BE THE STANDARD DISTANCE BETWEEN TO PILLARS
Wed Dec 02, 2009Post  #1
H S Rathi
H S Rathi
Post subject: Distance between pillars
The distance between pillars should be according to the requirement of construction site and load of RCC slab. Generally, the distance between two pillars may be 10ft. to 20 ft.
Wed Feb 24, 2010Post  #2
Seetharaman
Seetharaman
Post subject: Pillar Distance
In Chennai, I am planning to construct a 40 by 54 feet site. Can I go in for 3 Pillars across (for 40 feet, with 20 Feet gap between each pillar) and 4 pillar for the depth (54 Feet, with 18 Feet gap between each pillar).
Wed Feb 24, 2010Post  #3
Seetharaman
Seetharaman
Post subject: Pillar Distance - Cost
Will cost of construction increase if the distance between pillars are increased???
9229
pillar size in distacce
2101
12462
First floor construction
3608
18435
2950
Number and position of pillars
Last answer on 7/3/2020 10:41:58 PM. by Ananda. Forum started by Ananda
3238
4588
Reagarding Coulmn Pillar
Last answer on 9/29/2015 11:01:46 AM. by S L Gupta (Civil Engg). Forum started by Amit Kumar
3793
4389
Last answer on 11/15/2016 1:51:43 AM. Forum started by K Srinivasan
2758
Last answer on 8/26/2013 1:23:28 PM. by S L Gupta (Civil Engg). Forum started by ragha
1369
what is the standard labour outputs for different work in is code
Last answer on 7/4/2020 4:30:08 AM. by S L Gupta (Civil Engg). Forum started by santosh pore
1999
Standard Awnings For Home
Last answer on 7/3/2020 10:26:05 PM. by S L Gupta (Civil Engg). Forum started by Shel Jones
2808
3560
Cost of construction
Last answer on 3/19/2013 11:44:19 AM. by S L Gupta (Civil Engg). Forum started by saurabh ramya
12073
is it recommended distance between two pillars is 17'.0
Last answer on 10/17/2016 12:24:04 PM. by S L Gupta (Civil Engg). Forum started by Shanthamurthi
11057
Last answer on 1/25/2021 8:45:40 AM. by Irfan. Forum started by ani
3901
Last answer on 7/4/2020 4:17:36 AM. by S L Gupta (Civil Engg). Forum started by vinay
32561
Cost of RCC Pillar
6437
position of pillars
1878
column
1780
First floor plan suggestions
2524
Pillar cost
4037
12462
2501
2504
Length of cantilever beam
2537
RCC column (pillar)
9229
9196
2824
2695
1994
2208
3161
Laping length requirement
Brick Pillar
What is the standard thickness of glass for glass windows?
The standard thickness of glass
